Discuss
Kitchenaid intermittent cycle problems
 in
Dishwasher Repair
My Kitchenaid Superba KUDS01FLSS5 only operates intermittently and sometimes not at all. Starting up is not the problem but it
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kitchenaid intermittent cycle problems
  #1 (permalink)
Old 04-11-2011, 08:31 PM
Junior Member
Superburner is on a distinguished road
Default Kitchenaid intermittent cycle problems
Model Number: KUDS01FLSS5   Brand: Kitchen Aid   Age: 5 - 10 years
My Kitchenaid Superba KUDS01FLSS5 only operates intermittently and sometimes not at all. Starting up is not the problem but it cuts out during operation. I haven't experimented to see if this happens on all the cleaning modes but it does suffer this problem on "Normal" and "Quick Clean Up."
Opening and closing the door sometimes gets it to start back into the cycle which makes me think the door switch might be the issue?
Another possibility could be the heating element which has significant calcium build up on it and also a discolored spot that makes me wonder if it is cracked and therefore not working. I have confirmed that the water entering the dishwasher is 110 F but anytime the I check the water temp inside it appears less than 110 F and the element is not hot to the touch.
When this dishwasher heats the water does it do it based on a timer or does it measure the actual water temperature to confirm the 120 F setpoint is reached before continuing?
Can I fool it by opening the washer up and pouring in boiling water to bring it over 120 F. If I then close the door it continue on it's cycle?
Other strange performance characteristics are: the lights seem to illuminate based on door position, for example: with the door opened pass 45 degrees the clean mode LED is on, then as the door is shut the LED goes off. After 10 minutes or so the cycle might kick back in.
Back when this Dishwasher was bought and under warranty it had two new boards put in it as the were 'frying' eventually the service tech moved the unit further out from under the cabinet and the boards stopped over heating. Since then it's been reliable (4 years) until now.
Sorry for the epic. Thoughts?
Related Models
Whirlpool KUDS01FLSS5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01FLSS6 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01FLSS7 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01FLWH0 DISHWASHER
Whirlpool KUDS01FLWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01FLWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01FLWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01FLWH5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01FLWH6 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01FLWH7 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01IJAL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01IJAL1 DISHWASHER
Whirlpool KUDS01IJBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01IJBL1 DISHWASHER
Whirlpool KUDS01IJBS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01IJBS1 DISHWASHER
Whirlpool KUDS01IJBT0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01IJBT1 DISHWASHER
Whirlpool KUDS01IJWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01IJWH1 DISHWASHER
Whirlpool KUDS01ILBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBL5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBL6 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBS5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBS6 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBT0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBT1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBT2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBT3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBT5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILBT6 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILWH5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01ILWH6 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMMT0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMMT1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMMT2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMMT5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMMT6 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMMT7 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMSS5 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMSS6 UNDERCOUNTER DISHWASHER
Whirlpool KUDS01VMSS7 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRSS4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FRWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FSPA1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FSPA2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FSPA3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02FSPA4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02ISSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02ISSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRSS4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS02SRWH4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTBL0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTSS0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTWH0 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03CTWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSBL1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSBL2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSBL3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSBL4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSBT1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSBT2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSBT3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSBT4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSSS1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSSS2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSSS3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSSS4 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSWH1 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSWH2 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSWH3 UNDERCOUNTER DISHWASHER
Whirlpool KUDS03FSWH4 UNDERCOUNTER DISHWASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
HE4T intermittent power problems jayusa123 Dryer Repair 0 10-13-2010 04:34 PM
KitchenAid Water Disperser Intermittent Leak DjayR Refrigerator & Freezer Repair 5 09-09-2010 09:35 PM
Maytag Quiet Series 200 intermittent drain & dirty dish problems cbwebste Dishwasher Repair 0 01-19-2010 10:45 AM
Intermittent problem with the dry cycle bigotes Washer Repair 3 12-07-2009 07:08 PM
Intermittent starting of KitchenAid Dishwasher Howward Dishwasher Repair 4 09-18-2008 10:35 AM
