The dishwasher stopped in the middle of the cycle. Water is still standing in the dishwasher. There is power to the dishwasher, however when the door is closed the lights on the control panel do not light up. When you push on the area where the latch is located trying to make sure it is closed properly the lights do come on and the resume/start button flashes. When you push the resume/start button all the lights go out. Could this be the Actuator door latch or the Door Switch not functioning correctly and causing the dishwasher to not receive the correct signal to operate? Please Advise.
Thank you,
David Hansen 214-729-9695
