My dishwasher isn't draining. I have checked the drain hose and lookede at the drain valve. The valve has a strong magnetic field on it and the hose is clear. The pump works when the unit is in cleaning mode but doesn't come on when it should be draining, I know it use to pump when in drain cyle. What should I look for to come up with the answer?
