Bill Graves
#1 Posted : Sunday, April 3, 2011 1:41:35 PM(UTC)
Bill Graves
When you attempt to program start, it powers off. If you push the cancel or the start button, it sounds like it is attempting to drain. The tub appears to be empty. I assume there is a level indicator sensing water remaining.
Just inside the door on the right in the basin area is a float thing. It appears to have free travel up and down. I don't have a clue where to start. If I remove the thumb screw at the center of the water slinger, the slinger mech. comes off and a plastic ring and the pump assembly, I guess, is then exposed. It appears to be fastened down relatively well. I am not sure if I should remove the screws and continue further down or not.
If you have any suggestions, please, contact me at conservativevote@hotmail.com, I'd be happy to hear from you. Thx, Bill
