| » Maytag has new water valve, but no water |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: DWU9200AAX Brand: Maytag Age: 5 - 10 years
Water valve was leaking, so i replaced it. Water is coming through it because before i hooked up the rubber hose, i turned the water on and it spurted out. What should i look for now?
Model # DWU9200AAX MAYTAG. Thanks! |
Hi ultimatefighter34
The float (#32 on the tub break down diagram) is located in the left front corner inside the dishwasher. The float switch (#33 on the tub break down diagram) is located under the dishwasher. Check the position of the float and continuity across the switch terminals. Without water the float should be in bottom position and it has to move up and down easily. The switch without water should be close. Also check if the water shut off valve under the sink is open. - Here are the break down diagrams fro the Maytag dishwasher Model DWU9200AAX Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| Water Valve Problem? | Dave14 | Refrigerator & Freezer Repair | 16 | 10-26-2007 01:56 PM |
| Maytag Washer Inlet valve - water level switch | reisman | Washer Repair | 0 | 10-23-2007 08:36 PM |
| Water inlet valve | m/c | Refrigerator & Freezer Repair | 2 | 07-31-2007 10:34 PM |
| water flow valve | BRAND001 | Washer Repair | 0 | 07-23-2007 07:05 PM |
| Water inlet valve | gentleben | Refrigerator & Freezer Repair | 1 | 07-19-2007 11:04 AM |
