Discuss
Bosch dishwasher won't complete cycle
 in
Dishwasher Repair
My Bosch dishwasher, approx. 6 years old, has worked great until 6 months ago. Every once in a while, it
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher won't complete cycle
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-26-2007, 05:52 PM
brewstmp brewstmp is offline
Junior Member
brewstmp is on a distinguished road
Default Bosch dishwasher won't complete cycle
Model Number: SHU3032UC   Brand: Bosch   Age: 5 - 10 years
My Bosch dishwasher, approx. 6 years old, has worked great until 6 months ago. Every once in a while, it would fail to complete the cycle. The dial would stop moving, but the motor would continue running. Then next time I would try it a few days later, it would work fine. It didn't always stop at the same point in the cycle either. The problem seems to becoming more frequent. My mechanically gifted son checked it out. He couldn't find in blockages in the water supply and suspected it may be something in the dial or controller/timer. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-26-2007, 07:51 PM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
sound like a bad timer the part # for the timer is AP2804302
  #3 (permalink)
Old 11-07-2007, 02:48 PM
Junior Member
Default
Any idea why it works intermittently. If it doesn't complete the cycle, I can usually wait a few days and then it works fine. But if I do one load that goes through the entire cycle, and then try to wash another load immediately after, it won't complete.
  #4 (permalink)
Old 11-09-2007, 03:01 AM
sparepartspro sparepartspro is offline
Junior Member
sparepartspro is on a distinguished road
Default
Classic anti-flood symptom.
There is a float switch in the bottom of the plinth that when activated puts the machine into continuous drain mode.
If this occurs every other day or so then the water is drying out during this time and puts the machine back into run mode.
The next time it fails to run, tilt the machine back to drain any water out of the bottom and see if that fixes it.
Causes of flooding are due to operator chucking the soap tablet in the sump of the dishwasher on start up. The foam action creates a false rise in water level that then fills up the drip tray in the plinth.
Of course this is one of the most common of courses and I could go on to explain others but that is for another day. I'm sure this will fix it for you.
Kind regards Tony
  #5 (permalink)
Old 12-13-2007, 06:59 PM
Junior Member
Default
I replaced the timer, but still the same problem. Any other ideas?
  #6 (permalink)
Old 12-13-2007, 07:17 PM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default bosch d/w wont complete program ( heating problem )
usually if you advance the timer one click or two at whatever point it seems to be getting stuck at and it will continue until another point where it again gets stuck, it usually means that it is some sort of heating circuit problem. most often the timer is not the problem but more like a thermostat. i believe on that model, there are 2 thermostats in the door area, near the detergent dispenser ... most of the time, one of them is not sensing heat properly.. "thermomastic' is important when replacing those thermostats as heat transfer is very important..
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't complete cycle-grinding noise rebekah Washer Repair 2 12-13-2007 07:20 PM
dishwasher instructions to replace complete motor and pump assembly needed Nancy Ramsey Dishwasher Repair 0 10-25-2007 12:22 PM
Another Bosch not completing cycle robink Dishwasher Repair 1 10-16-2007 01:12 PM
Bosch Dishwasher JohnM Dishwasher Repair 6 09-04-2007 08:06 AM
Bosch Dishwasher won't cycle dspecht Dishwasher Repair 2 08-14-2007 11:46 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
