| » Washer machine will not fill with water |
Model Number: rax6144ew1 Brand: Roper Age: More than 10 years
I have a washer machine that everything works except no water will come when it is suppose to fill . I have cleaned the filters on the inlets. I took the "valve" that the hoses hook up to and took it apart. There are wires attached to the valve that open and close the water lines. I get a 12v reading on the wires when I turn the washer timer to any setting that requires water. So my question is, is the timer malfunctioning or do I need to replace the "valve" ?
If you have any other ideas on why the water isn't being allowed to fill the washer I would appreciate it. Ads By Google Related Models |
Replacement parts for WHIRLPOOL RAX6144EW1 | AppliancePartsPros.com See the attachment for the wiring diagram Try different temperature settings to see if all of them do not fill. Would be strange that both sides of the valve would go out ate the same time. Check that the water level switch V to P is closed.
__________________
| Display Modes | |
| Problem with cold water fill hose on washing machine. | Need2WashMyClothesplzthx | Washer Repair | 1 | 12-11-2010 05:29 PM |
| wahing machine wont fill on warm or cold water | Mickey Spurgin | Washer Repair | 1 | 02-14-2010 12:57 PM |
| Washing machine does not fill up with water | Eddiedean | Washer Repair | 1 | 01-29-2010 11:14 AM |
| cold water fill without machine on. | ron baker | Washer Repair | 2 | 09-18-2009 06:40 AM |
| Washer will continue to fill, even when machine is off. | gemelli1975 | Washer Repair | 3 | 05-20-2009 02:10 AM |
