Hello,
I have an Amana Dishwasher that when I cycle washer for a new washing cycle it fills up all the panel display works but main motor will not run. I had our service guy over here and he told me that the pump and or motor was bad. He said the bearing in the main motor was worn causing the motor to burn out. I purchased a new motor along with an impeller repair kit and installed all new parts including motor, Turbitity sensor, and a new temp sensor, and still does not work?? What is your thoughts on this could it be the control assembly bad circuit board?? That was my thought a along but want a 2nd opinion befor buying a $120.00 part!!
