I’m looking for a tech sheet for Whirlpool dishwasher 7GU3800XTVY0. According to appliancepartspros the part number is: AP4684540 but they do not have it available.
The problem I have with the dishwasher is that it doesn’t start the cycle. After I press START, I can hear the machine filling with water, the makes a pause and tries to start the cycle, a noise is heard and then START led keeps blinking, if I press START again it will make the noise again and START led will keep blinking.
First I though that the board was defective, but after replacing it, still doing the same thing.
I want to run a diagnostic cycle to determine what is causing the problem.
Thank you, Juancho
