Discuss
DW Location of heating element
 in
Dishwasher Repair
Cab someone tell me or send a diagram showing the location of the heating element for my Bosch dishwasher? Also
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » DW Location of heating element
  #1 (permalink)
Old 03-23-2011, 05:58 PM
Junior Member
vanzant is on a distinguished road
Default DW Location of heating element
Model Number: SHU9915UC/15   Brand: Bosch   Age: 5 - 10 years
Cab someone tell me or send a diagram showing the location of the heating element for my Bosch dishwasher? Also is it hard to replace or get to?
Thanks for your help.
Related Models
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Bosch SHV4803 UC/06 (FD 7712-7812, 7905-7907)
Bosch SHV4803 UC/07
Bosch SHV4803 UC/07 (FD 7812-7905, 7907-8010)
Bosch SHV4803 UC/12
Bosch SHV66A03 UC/14 (FD 8301-)
Bosch SHV6803 UC/12 (FD 8105 -)
Bosch SHV99A03 UC/14 (FD 8212-)
Hoover SHWA2501A WASHER-TOP LOADING
Hoover SHWA2501W WASHER-TOP LOADING
Hoover SHWA2506A WASHER-TOP LOADING
Hoover SHWA2506AT WASHER-TOP LOADING
Hoover SHWA2506W WASHER-TOP LOADING
Hoover SHWA2506WT WASHER-TOP LOADING
Hoover SHWA2507V WASHER-TOP LOADING
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E REF - SXS/I&W
General Electric SIG140060B SIGNATURE REFRIGERATOR
General Electric SIG1480A66WH DISHWASHER
General Electric SIG1482A68BA DISHWASHER
General Electric SIG60100T0WG SIGNATURE WASHER
General Electric SIG7010ET0WG SIGNATURE ELECTRIC DRYER
General Electric SIG7010ET1WG Electric dryer
Admiral SILVER22 REF - SXS/I&W
Admiral SILVER24 REF - SXS/I&W
Maytag SK525-2W REF - SXS
Maytag SK535-2 REF - SXS/I&W
Gaggenau SK590-2 REF - BOTTOM MOUNTS
Hardwick SKG4622MGA639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG4622MGW639R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611A540R RANGE-F/S CONT CLEAN GAS
Hardwick SKG9611W540R RANGE-F/S CONT CLEAN GAS
Amana SKI22F REF - SXS/I&W
Amana SKI22F-A REF - SXS/I&W
Amana SKI22F-C REF - SXS/I&W
Amana SKI22F-G REF - SXS/I&W
Amana SKI22FL REF - SXS/I&W
Hardwick SKJ7141819DE WALLOVEN- CONT CLEAN GAS
Maytag SL10AN-A01 STACKED LAUNDRY- ELE
Maytag SL10AN-A02 STACKED LAUNDRY- ELE
Maytag SL10AN-A03 STACKED LAUNDRY- ELE
Maytag SL11AA STACKED LAUNDRY- ELE
Maytag SL11AN STACKED LAUNDRY- ELE
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F REF - SXS/I&W
Amana SL22F-A REF - SXS/I&W
Amana SL22F-C REF - SXS/I&W
Amana SL22F-G REF - SXS/I&W
Amana SL22F-L REF - SXS/I&W
Amana SL22G REF - SXS/I&W
Amana SL22GL REF - SXS/I&W
Amana SL22JB REF - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG REF - SXS/I&W
Amana SL22MBL REF - SXS/I&W
Amana SL22MBW REF - SXS/I&W
Amana SL25G REF - SXS/I&W
Amana SL25GL REF - SXS/I&W
Amana SL25H REF - SXS/I&W
Amana SL25J REF - SXS/I&W
  #2 (permalink)
Old 03-24-2011, 10:57 AM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
Hello. The heating element is located in the bottom of the dishwasher on the sump assembly. You will need to uninstall the dishwasher to remove it. They are a little hard to get to. Here are the manufacture instructions. Hope this helps.
Heater s & NTC’s – Access (1)
To remove outer door:
��Remove six (6) T-20 Torx screws from inner door below fascia panel (three (3) per side).
��Carefully pull bottom of outer door out from dishwasher until top door tabs clear, then pull door down until it releases from dishwasher. Take care to not scratch outer door.
��Remove two (2) plastic door guards. They can fall out when the outer door is removed.
The heater & NTC can be accessed or measured from the right side of the dishwasher, but can only be removed by dropping the entire base (by flipping the dishwasher on its back) since they are wedged underneath the tank.
To separate base from tank (1):
��Carefully lay dishwasher on its back.
��Carefully pull door springs out from base.
��Remove terminal blocks from base.
��Separate water valve from base by removing two (2) T-20 Torx screws, then move water valve out of the way.
Disconnect J-box ground wire, then pull wires out of J-box.
��Pull out inlet hose from sump.
��Carefully pull base away from tank and sump.
Removing & Installing Heater & NTC:
��Remove two (2) T-20 Torx screws holding heater assembly to sump.
��Disconnect wires from heater, flow switch, NTC & Hi-Limit after noting connections.
��Pull clips, then carefully pull heater assembly from sump & pump. Note heater comes as an assembly (with housing & gasket).
Remove heater assembly --NTC is located on top of heater assembly.
��Disconnect wires after noting connections (since NTC & Hi-Limit are included in the same part --# 165281).
��Remove NTC cover, pull NTC holding tabs apart and pull NTC out of heater.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-24-2011, 12:12 PM
Junior Member
Default Bosch heating unit
Thanks for your reply. It should be very helpful, however I was wondering if there are any visuals for this procedure. Just trying to make it as easy as possible.
  #4 (permalink)
Old 03-24-2011, 12:37 PM
Senior Expert
Default
Sorry, At this time, I don't have any visuals to upload. Thanks.
__________________
Jeff K. / APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Identifying element relay location kazamy2 Oven Repair (including Ranges and Cooktops) 2 03-29-2010 03:34 PM
Heating Element On/Off buttons don't work. Element stays on mostly. juliotamu01 Dishwasher Repair 0 11-13-2009 06:05 AM
Replaced heating element now heating element nor broil element work, all else does rontetley Oven Repair (including Ranges and Cooktops) 1 10-26-2009 01:30 PM
bake element not heating but broil element heating okay horno Oven Repair (including Ranges and Cooktops) 1 10-04-2009 11:37 AM
Heating element location llyod Dryer Repair 4 01-10-2009 09:36 PM
