Discuss
Dishwasher fills and drains and runs trough cycles but doesnt wash
 in
Dishwasher Repair
I just recently purchased a house with a GE Triton Stainless Steel dishwasher. We loaded the dishwasher and ran it.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher fills and drains and runs trough cycles but doesnt wash
  #1 (permalink)
Old 10-24-2007, 01:00 PM
ryan6663 ryan6663 is offline
Junior Member
ryan6663 is on a distinguished road
Default Dishwasher fills and drains and runs trough cycles but doesnt wash
Model Number: GSD5860GOOSS   Brand: GE   Age: 1 - 5 years
I just recently purchased a house with a GE Triton Stainless Steel dishwasher. We loaded the dishwasher and ran it. The next morning when I opened the washer, I found a load of dirty dishes. I reran the washer to find it was filling and draining normally but during the wash cyclces there was no activity. There was no pump noise, no water cycling through the spray arms etc. Just filling, sitting and draining. It doesnt look like a very old machine. We do have high iron in our water, we have a well, and the inside of the machine has some staining inside. Any ideas please let me know, I would like to use this washer since it doesnt seem to be very old. Thanks!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-24-2007, 05:11 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Ryan
Most likely the problem with your dishwasher is a frozen up main pump. You have two options:
a) You can try to rebuild the old pump. In that case you need the pump seal and impeller kit which comes with the complete instructions. The pump and motor assembly has to be removed from the dishwasher.
b) You have to replace the whole pump and motor assembly.
- The part number for the pump seal and impeller kit AP631386
- The part number for the pump and motor assembly AP2616850
Also, I believe, your dishwasher is on the GE dishwashers recall due to problem with a rinse agent dispenser. You can verify it on the GE web site: http://www.geappliances.com/products/recall/dw07/
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
fills up and drains immediately dennis b Washer Repair 3 12-14-2007 12:41 PM
Dishwasher runs constantly cvonhag Dishwasher Repair 5 11-06-2007 03:44 PM
Sears Ultra Wash Dishwasher jfreder Dishwasher Repair 1 10-05-2007 05:13 AM
GE Washer Tank Fills but No Spin/Wash/Drain jrgreulich Washer Repair 3 09-02-2007 06:09 PM
Can not select wash cycle - stuck on scrub wash luke Dishwasher Repair 0 08-20-2007 09:38 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
