| » Dishwasher key lock won't unlock (white) |
Model Number: 665.13592k600 Brand: Kenmore Age: 1 - 5 years
The keypad lock is enabled (green lock light on) and won't reset when holding in the button for 4 seconds per the manual's direction. All keys are literally locked rendering my machine useless! I read about a similar issue but with different brand- said new console was probably needed? Can you please advise what part number is needed for my problem?
Thanks |
Hi Steve
If the control senses one or more pads stuck, it stops the dishwasher and locks out the key pad. In order ti fix it the console has to be replaced. - The part number for the new white console AP3885210 Good luck. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Help!
I replaced the console but the problem did not go away-the key lock is still on. Do you think I need a board? Please list part number of suspected cause. Thanks, S Last edited by STEVE DOE : 11-03-2007 at 05:16 PM. Reason: want others opinion |
Hi Steve
This is very unusual but looks like the control board has to be replaced too. - The part number for the new control board AP3961536 Gene.
__________________
Steve,
How did you end up back in November? Which parts did you replace? Gene.
__________________
Gene,
I had to replace the control board 2x already- I just replaced it a month ago and used it only 1 time since. It is almost like I have a lemon dishwasher. Never needed to replace the new white console AP3885210. What do you think is wrong? Thanks, |
Steve,
What are these buttons? Did you check the door switches? Gene.
__________________
| Display Modes | |
| oven door will not lock | Dennis Loose | Oven Repair (including Ranges and Cooktops) | 0 | 10-08-2007 06:37 PM |
| white-westinghouse dishwasher. | mommieof2 | Dishwasher Repair | 1 | 09-19-2007 07:10 PM |
| White Westinghouse washer won't spin | help_me_please | Washer Repair | 1 | 09-19-2007 05:29 AM |
| Unlock Duet Washer Door | pcijohn | Washer Repair | 3 | 08-29-2007 09:43 PM |
| Door will not lock | hossross | Washer Repair | 0 | 08-25-2007 10:28 AM |
