| » Leak down float assembly |
Model Number: kuds230bwho Brand: Kitchen Aid Age: 5 - 10 years
There is a water leak comming down the stand pipe of the float switch assembly. I ordered a float switch assembly and do not think that will solve the problem, since the float looks different on line and there is a space when the shaft of the float goes into the switch assembly. Is there suppose to be a gasket inside the float to prevent water going down the assembly shaft.
Pull front bottom panel and remove the float retaining clip and remove float. Check the tub, you will probably find a crack in the tub. Sand it and clean it and put some silicone cement on it.
__________________
| Display Modes | |
| How do I remove a FLoat Valve ASsembly? | geraldgthom | Dishwasher Repair | 0 | 10-03-2009 10:35 AM |
| Dishwasher leak down float tube | Kathy R | Dishwasher Repair | 7 | 05-13-2009 05:55 AM |
| Drain and Float Question | Remov1 | Dishwasher Repair | 1 | 01-07-2009 07:02 AM |
| Float and Washer Assembly | lwb | Dishwasher Repair | 4 | 08-01-2008 07:27 AM |
| Float w/ washer necessary? | lwb | Dishwasher Repair | 1 | 07-30-2008 09:00 PM |
