Discuss
Leak down float assembly
 in
Dishwasher Repair
There is a water leak comming down the stand pipe of the float switch assembly. I ordered a float switch
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Leak down float assembly
  #1 (permalink)
Old 10-23-2007, 01:33 PM
David Maheu David Maheu is offline
Junior Member
David Maheu is on a distinguished road
Default Leak down float assembly
Model Number: kuds230bwho   Brand: Kitchen Aid   Age: 5 - 10 years
There is a water leak comming down the stand pipe of the float switch assembly. I ordered a float switch assembly and do not think that will solve the problem, since the float looks different on line and there is a space when the shaft of the float goes into the switch assembly. Is there suppose to be a gasket inside the float to prevent water going down the assembly shaft.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-24-2007, 03:10 AM
richappy richappy is online now
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull front bottom panel and remove the float retaining clip and remove float. Check the tub, you will probably find a crack in the tub. Sand it and clean it and put some silicone cement on it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
RE: Clock Assembly or Temperature Sensor Joyce Oven Repair (including Ranges and Cooktops) 0 10-20-2007 02:12 PM
Clock Assembly or Temp Sensor? Joyce Oven Repair (including Ranges and Cooktops) 5 10-20-2007 02:07 PM
How to replace clock assembly? honk Oven Repair (including Ranges and Cooktops) 0 09-20-2007 05:42 PM
Removing pump motor assembly dcherioke1 Dishwasher Repair 1 09-14-2007 11:50 AM
Door latch assembly or user interface? CMC1 Washer Repair 1 08-10-2007 11:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
