Discuss
NO WATER in old Kenmore Dishwasher
 in
Dishwasher Repair
The machine was working, but leaking water from inlet valve (AP#3050333). I removed the assy., disassembled, cleaned and replaced it.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » NO WATER in old Kenmore Dishwasher
  #1 (permalink)
Old 03-12-2011, 09:22 PM
Junior Member
LesterS is on a distinguished road
Default NO WATER in old Kenmore Dishwasher
Brand: Kenmore   Age: More than 10 years
The machine was working, but leaking water from inlet valve (AP#3050333). I removed the assy., disassembled, cleaned and replaced it. Now there is no water getting into the machine. The water supply is on and I checked that the float is not stuck in the up position.
Ads By Google
  #2 (permalink)
Old 03-13-2011, 01:35 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
It is not uncommon for these valves to fail after they have been opened up.
You could check for voltage across the valve (120 volts) when it should be filling.
If you have voltage and it does not open then I would replace the valve.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore dishwasher water fill problems bmanapp Dishwasher Repair 1 09-13-2010 03:26 AM
Kenmore dishwasher motor won't pump water out astro3ron Dishwasher Repair 5 09-03-2010 10:39 AM
Kenmore Elite Dishwasher water leak davedishwasher Dishwasher Repair 0 07-15-2010 09:21 AM
Kenmore dishwasher water backup checkin Dishwasher Repair 1 09-21-2009 08:35 PM
Kenmore dishwasher not spraying water at the third level ilikebikes Dishwasher Repair 1 10-17-2007 03:34 PM
