Discuss
GE Dishwasher - wont drain correctly/pump works?
 in
Dishwasher Repair
Hi, My wife and i started noticing that our dishwasher wouldnt drain. I took it apart and found a few
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Dishwasher - wont drain correctly/pump works?
  #1 (permalink)
Old 03-12-2011, 06:40 AM
Junior Member
Jondoyle24 is on a distinguished road
Default GE Dishwasher - wont drain correctly/pump works?
Brand: GE   Age: 1 - 5 years
My wife and i started noticing that our dishwasher wouldnt drain. I took it apart and found a few things in the bottom of a one way diaphram.
I disassembled the line from the pump back to the air gap and all the way down to the disposal and found no kinks or blockages.
I reassembled and ran again, same thing.
I searched this site and found another thread about non-draining issues and ran a rinse cycle. for the last 2 minutes there was a low sound from the bottom, that was kind of a buzzing and i saw and felt water in the line to the air gap. i believe it was moving, but i dont know how hard or fast since i DID see a few air bubbles moving inside the clear tube.
Can a pump be partially dead, i.e. not enough pressure to send the water back? i dont see any blocks in the line and dont want to start tearing it all apart.
thanks in advance. this is my first time to this site and its fantastic. i see alot of future purchases coming from here for me :0)
JON
Ads By Google
  #2 (permalink)
Old 03-12-2011, 11:00 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you
Model Number Locator
__________________
  #3 (permalink)
Old 03-12-2011, 11:41 AM
Junior Member
Default
Ge Gld5700n00bb
i found an electrical schematic and some basic trouble shooting instructions folded up under the unit.
I entered the Technicians mode, and pressed option #2 which tests the Main Pump for 2 minutes. At the end of 2 minutes the water was still at the bottom.
I performed the same text option #3 for the Auxillary Pump. That ran for a minute and removed 100% of the water at the bottom. I than proceeded to refill the bottom of the unit with a few pots of water, ran Main pump test which didnt do anything.. and then ran Aux. pump test again which ultimately emptied the entire bottom again which i could see and hear emptying into the sink.
Im confused: the wiring schematic shows a pump. it doesnt show an auxillary pump...
Also, i broke out my volt meter and i have 120 volts at the pump.
this is all the troubleshooting ive been able to do so far.
thanks for anyhelp everyone.
J
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ge nautilus dishwasher wont drain and sprayarms wont spin James Jenkins Dishwasher Repair 0 07-25-2010 05:59 PM
GE washer wont agitate correctly but will fill, spin, drain. z_thompsonpa Washer Repair 1 06-21-2010 05:07 PM
dishwasher will not drain (drain pump is new) jkda1975 Dishwasher Repair 1 04-06-2010 01:56 PM
Dishwasher drain pump leaks nuker3 Dishwasher Repair 0 01-20-2010 09:43 AM
bosch shu9925 - drain pump works, won't drain after cycle mjbarr Dishwasher Repair 0 10-16-2009 01:11 PM
