Discuss
Bosch SHU43C won't shut off at cycle end
 in
Dishwasher Repair
My Bosch diswasher seems to cycle perfectly, dishes clean, normal sounds, normal countdown on display, etc. Timer counts down to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch SHU43C won't shut off at cycle end
  #1 (permalink)
Old 12-28-2008, 02:46 PM
Junior Member
freesteamin is on a distinguished road
Post Bosch SHU43C won't shut off at cycle end
Model Number: SHU43C07UC/17   Brand: Bosch   Age: 1 - 5 years
My Bosch diswasher seems to cycle perfectly, dishes clean, normal sounds, normal countdown on display, etc. Timer counts down to 0 on display but circulation pump just keeps running forevever. At cycle end I can hear the drain pump turn on several times and water drains each time it turns on. Then the only sound is the circulation pump running (at least I think its the sound of the circulation pump). When I open the door well after the cycle ends (display at "0"), the machine stops as normal but water is still spurting out of the lower control arm for a second or two. I assume that is a consequence of the circulation pump running and circulating the residual water in the sump. There is about 1" of water left in the sump. The drain line is clear and the backflow flapper looks okay. Same behavior on all modes including drain/cancel. Any suggestions would be appreciated.
Related Models
Bosch SHU43E02 UC/14 (FD 8211-)
Bosch SHU43E05 UC/14 (FD 8211-)
Bosch SHU43E06 UC/14 (FD 8211-)
Bosch SHU43E07 UC/14 (FD 8211-)
Whirlpool SHU45010 Dishwasher
Whirlpool SHU45020 Dishwasher
Whirlpool SHU50041 Dishwasher
Whirlpool SHU50043 Dishwasher
Bosch SHU5302 UC/06 (FD 7705-7912)
Bosch SHU5302 UC/11 (FD 8001-8003)
Bosch SHU5302 UC/12 (FD 8003-)
Bosch SHU5304 UC/06 (FD 7705-7912)
Bosch SHU5304 UC/11 (FD 8001-8003)
Bosch SHU5304 UC/12 (FD 8003-)
Bosch SHU5305 UC/06 (FD 7705-7912)
Bosch SHU5305 UC/11 (FD 8001-8003)
Bosch SHU5305 UC/12 (FD 8003-)
Bosch SHU5306 UC/06 (FD 7705-7912)
Bosch SHU5306 UC/11 (FD 8001-8003)
Bosch SHU5306 UC/12 (FD 8003-)
Bosch SHU5307 UC/12 (FD 8003-)
Bosch SHU5312 UC/06
Bosch SHU5312 UC/11
Bosch SHU5312 UC/12
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55010 Dishwasher
Whirlpool SHU55040 Dishwasher
Whirlpool SHU55042 Dishwasher
Whirlpool SHU60020 Dishwasher
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70010 Dishwasher
Whirlpool SHU70041 Dishwasher
Whirlpool SHU70050 Dishwasher
Whirlpool SHU70051 Dishwasher
Whirlpool SHU70052 Dishwasher
Whirlpool SHU75010 Dishwasher
Whirlpool SHU75042 Dishwasher
Whirlpool SHU80010 Dishwasher
Whirlpool SHU80041 Dishwasher
Whirlpool SHU80042 Dishwasher
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90002 Dishwasher
Whirlpool SHU90041 Dishwasher
Whirlpool SHU90050 Dishwasher
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99041 Dishwasher
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99052 Dishwasher
Whirlpool SHU99053 Dishwasher
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
  #2 (permalink)
Old 12-28-2008, 08:07 PM
Senior Expert
APP Volunteer
jdappl07 is on a distinguished road
Default
Is the water still dirty or clean? if it is the machine has a aqua sensor that if the water is still dirty the machine can still run until the sensor can see clean water. if it is clean you may have a bad sensor or control board. also has a water temp sensor can also do it if the heater isnt working if it doesnt heat properly the dish will not dry at the end. Therefore, extending the cycle
__________________
J&D Appliance Repair Serving Pendleton County, Kentucky and Surrounding Areas
  #3 (permalink)
Old 12-29-2008, 07:38 AM
Junior Member
Default
Thanks for the quick response! The water is definitely clean. I even ran an empty washer on the regular cycle for a couple of minutes to fill it up with clean water then pressed the drain/cancel to end the cycle. Same behavior. If the sensor is bad, wouldn't it cause the machine to try to run more rinse cycles? In my case, nothing appears to happen except the circulation motor runs forever. I can't hear any rinse water being introduced and the drain pump never runs again. The first time this happened we started the machine in the evening and the circulation motor was still running in the morning. When you say a heater fault or temp sensor fault can extend the cycle, could the cycle be extended by 10 hours or more?
  #4 (permalink)
Old 12-31-2008, 08:47 AM
Junior Member
Default
Dishwasher now appears to be running correctly! I'm not completely sure which of the many things I did was responsible but, for anyone else having this problem, here's what I did. I turned the circuit breaker off for several hours but that didn't fix it. I then checked the pan for water (none), the float for binding(none), and the float switch for proper operation(all okay). I then took apart the door, pulled out the control module and inspected the two circuit boards. I had read the notes about resoldering of the heater pin. The pin on my board looked good and I had verified that the heater was working but I decided to resolder it anyway. Reassembled everything and, tada, it worked perfectly. My conclusion is that either the heater pin was a cold solder joint and it somehow created the symptoms I had or there was a bad connection from the circuit board to one of the many connectors that plug into it and my disassembly/ reassembly fixed the connection. Small possibility that my fiddling with the float and float switches on the side of the machine might have fixed it but everything was clean as a whistle in that area so I don't think so.
  #5 (permalink)
Old 01-20-2009, 05:42 AM
Junior Member
Default
An update on my problem. After working perectly for the last few weeks, the same symptoms started again and have persisted for a few days. In another forum, I corresponded with someone who had the same problem. They were told that the clear water sensor might be covered with a film and they should run several cycles with an empty machine but using jet dry to clean the sensor. I filled my jet dry dispenser and adjusted it for maximum dose then ran several quick wash cycles. Seems to be working now. We have been using the all-in-one gel packs over the past six months. I wonder if they are causing some sort of problem? ALternatively I wonder if it will cause any problems if we continue to use the gel packs plus the jet dry?
  #6 (permalink)
Old 03-03-2015, 05:57 AM
Junior Member
Gregier007 is on a distinguished road
Smile Same problem
I did the same. Extra Jet dry, even squirted in bottom of dishwasher and set to highest level for auto of jet dry. Ran three quick wash and then a rinse and hold 3 hours latter. Runs great then shuts off as normal. Tested rinse and hold one mor time this morning. Shut off as normal. Now running a regular wash.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune Washer Shut off in mid cycle rleinen Washer Repair 43 03-02-2015 12:02 PM
Bosch wont shut off Charlie.Keeton Dishwasher Repair 1 12-04-2009 05:26 PM
Defrost cycle won't shut off ajgroot Refrigerator & Freezer Repair 1 09-05-2009 02:17 AM
Bosch D/W just clicks when I shut the door cf2112 Dishwasher Repair 0 08-30-2009 04:54 AM
No Dryer Heat/No shut of in auto cycle fred2117 Dryer Repair 4 04-30-2009 04:59 PM
