Discuss
Cycles On When Door Is Closed
 in
Dishwasher Repair
Need help with this problem...The normal cycle stars and is completed. The dishwasher then starts the normal cycle on
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Cycles On When Door Is Closed
  #1 (permalink)
Old 10-22-2007, 09:48 AM
GEARHEAD GEARHEAD is offline
Junior Member
GEARHEAD is on a distinguished road
Default Cycles On When Door Is Closed
Model Number: GU980SCGQ0   Brand: Whirlpool   Age: 5 - 10 years
Need help with this problem...The normal cycle stars and is completed. The dishwasher then starts the normal cycle on its own...no buttons presed. To stop the cycle I press the cancel button the unit will stop and the lock light blinks. If I open and close the front door the unit will start in normal cycle on its own.
operation panel or control board?
Last edited by GEARHEAD : 10-22-2007 at 08:17 PM. Reason: more informatiom on problem
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-23-2007, 03:50 AM
richappy richappy is online now
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Seems like a shorted key pad. No way to test, just order a new one.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not change cycles automatically bad bart Washer Repair 0 10-16-2007 01:23 PM
Gas Dryer not drying during run cycles GMP Dryer Repair 1 09-28-2007 08:42 AM
washer stops at different cycles kfoerster Washer Repair 3 09-27-2007 03:37 AM
stops on heating delay between cycles scoot Dishwasher Repair 1 09-13-2007 03:14 AM
Whirlpool washer will not advance cycles GARY H Washer Repair 0 08-14-2007 07:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
