Want to replace stainless steel inner door panel (all scratched up). Any instructions available. Panel comes with hinges; don't think I need to replace these though? Can the panel be replaced while leaving dispenser alone, that is, will the panel just slip by the dispenser? There are many screws holding panel on and assume some hold other things in place. Any things to be especially careful about?
