kingmarkyd
#1 Posted : Sunday, March 6, 2011 4:19:54 PM(UTC)
kingmarkyd
HAD A QUIET ARTNER II replaced control panel then thermal fuse got it up and running using reset keys now getting continuous blinking rinse only light what do I do! Spent major money on new board and fuse still no luck but for one half cycle.
Joe / APP Team
#2 Posted : Monday, March 7, 2011 1:25:54 PM(UTC)
Joe / APP Team
Kingmarky,
You most likely have(had) a or several bad keypad(s).
ERROR MESSAGES
STUCK KEY:
If the control detects that a key is stuck in
the depressed position, dishwasher
operation will be suspended and the
control will flash the light for that key until
the condition is corrected. If a key without
a light is stuck/shorted or multiple keys are
stuck/shorted, the control will flash the
Rinse cycle key light.
RAPID ADVANCE SERVICE FEATURE AND
DIAGNOSTICS CYCLES
Pressing the following option keys in the sequence shown will either start
the Diagnostics Cycle or turn on the Rapid Advance feature for customer
selectable cycles:
HI TEMP WASH → AIR DRY → HI TEMP WASH → AIR DRY
- or -
HI TEMP SCRUB/SCOUR
→ AIR DRY → HI TEMP SCRUB/SCOUR → AIR DRY
If the above key sequence is entered with the dishwasher in Standby, the
Diagnostics Cycle is started. The operator can advance the cycle, interval
by interval, by pressing the Pots & Pans or Anti-Bacteria key.
You could also try, disconnecting the touchpad ribbon, from the new control board, thoroughly clean the insertion end of the ribbon with alcohol, re insert the ribbon, properly and tightly, and try again, after you reset the control board.
Good Luck,
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Heat Failure; Stumped! (Dryer Repair)
by ClotheslineChris 10/17/2017 10:41:02 AM(UTC)
DIY troubleshooting, now stumped (Dryer Repair)
by mmorlan62 2/28/2017 12:17:08 PM(UTC)
GE dishwasher won't heat - stumped (Dishwasher Repair)
by lwolniak 1/24/2017 6:59:20 AM(UTC)
No bake, igniter and valve have continuity..stumped (Oven Repair (including Ranges and Cooktops))
by Breene 12/7/2016 12:42:05 PM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
Kenmore Washer --- stumped... NEED ADVICE! (Washer Repair)
by rlhfixit 6/5/2015 12:37:35 PM(UTC)
OK.. completely stumped! (Dryer Repair)
by akostrzewa77 10/15/2014 4:23:42 AM(UTC)
by Leg_Cramp85 7/15/2014 11:55:59 PM(UTC)
Whirlpool Gold Ice Maker Problem - Stumped! (Refrigerator & Freezer Repair)
by ljsmith1 11/25/2013 6:06:51 PM(UTC)
Stumped on Freezer Problem (Refrigerator & Freezer Repair)
by mmccarty 3/29/2012 12:35:37 PM(UTC)
Stumped (Refrigerator & Freezer Repair)
by shballard7 8/2/2011 9:57:21 AM(UTC)
Stumped! Replaced Oven Sensor, Still Not Working! (Oven Repair (including Ranges and Cooktops))
by Debelli 12/4/2010 11:13:00 AM(UTC)
frigidaire- how to replace glass top-stumped! (Oven Repair (including Ranges and Cooktops))
by chipley 10/6/2010 7:13:30 AM(UTC)
Clothes still soaked -- NeptuneTL - still stumped (Washer Repair)
by dprimm 7/26/2010 4:26:08 PM(UTC)
