Discuss
dishes not clean
 in
Dishwasher Repair
I moved into a house with a miele g575 dishwasher. It advnace through all the cycle properly but food particles
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishes not clean
  #1 (permalink)
Old 10-21-2007, 08:29 PM
feinerl feinerl is offline
Junior Member
feinerl is on a distinguished road
Default dishes not clean
Model Number: Miele g575   Brand: -other-   Age: 5 - 10 years
I moved into a house with a miele g575 dishwasher. It advnace through all the cycle properly but food particles remain and are getting dryed on the the dishes and cutlery. I have checked the water inlet and the drain which both appear to be free of blockage? Any ideas? Is this a good unit?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-22-2007, 03:42 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Is the water level up near the heating element, if so, open door while running and confirm washer spray arm is turning and spraying water all over. If not you have either a clogged pump or clogged spray arm.
If not full, drain washer and time the water fill, should be for more than 40 seconds.If not you have a bad timer or control module. If longer than 40 seconds and tub not full, you have a clogged screen in the water solenoid.
__________________
  #3 (permalink)
Old 10-22-2007, 06:20 AM
Junior Member
Default
The water level is up to the element and I removed and checked the spray arms. How do I access those other areas to check them? Do I have to pull out the dishwasher?
  #4 (permalink)
Old 10-22-2007, 04:48 PM
Senior Expert
APP Volunteer
Default
Open the door whole washer is washing and check if spray arm is spraying and turning.
__________________
  #5 (permalink)
Old 10-22-2007, 05:31 PM
Junior Member
Default
No It is not!. The water pouring out from the top of the unit is missing the funnel that directs it to the top spray arm. The bottom one is not turning either! They both turn freely when I spin them though. What is wrong?
  #6 (permalink)
Old 10-22-2007, 08:07 PM
Senior Expert
APP Volunteer
Default
Simply click on your model # above and order the missing funnel. Make sure the base that it threads into is ok. Some are left hand thread and some are right.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F1 Error After Self Clean karenhorton Oven Repair (including Ranges and Cooktops) 2 10-26-2007 03:32 PM
Dirty Dishes Janiece Dishwasher Repair 2 10-05-2007 04:40 AM
Bosch Dishwasher not clean Savannah9999 Dishwasher Repair 1 09-21-2007 10:52 AM
Water doesn't drain, spotty dishes cherienoel Dishwasher Repair 1 09-16-2007 07:24 AM
Top rack not clean boscoe Dishwasher Repair 3 08-14-2007 01:59 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
