| » solenoid frozen, armature has melted plastic |
Model Number: gsd2200g00ww Brand: GE Age: 1 - 5 years
I have frozen soleniod part # ap2039738 , and the dishwasher won't drain. There is melted plastic around the armature of the solenoid .What can cause this melting or sticking of this solenoid? Will replacing the solenoid repair the no draining problem?
Replacement parts for General Electric GSD2200G00WW Dishwasher | AppliancePartsPros.com Replacing the solenoid should repair the drain problem but you may also have a timer problem. I would remove the solenoid and then manually operate the drain valve arm just to be sure that you do not have a mechanical problem with the wash/drain flapper valve. The way the drain is supposed to work is that the timer activates the drain solenoid for a couple seconds. This pulls the solenoid and flapper valve into the drain position. The water pressure then holds the flapper in the drain position until the unit has drained and then the spring pulls it back to the wash position. If the timer contacts that send power to the solenoid start sticking closed then it gets power for too long and overheats the solenoid.
__________________
| Display Modes | |
| melted front tub | Scottsmarine | Washer Repair | 0 | 08-30-2010 08:10 PM |
| Heat won't shut off melted plastic wear and spray arm | golfpro | Dishwasher Repair | 0 | 12-06-2009 07:34 PM |
| melted part | Cahem | Microwave Repair | 0 | 11-10-2009 09:12 PM |
| melted vane | satyr | Dryer Repair | 1 | 05-08-2009 08:36 AM |
| Melted plastic on my glass stove top | marlamb@comcast.net | Oven Repair (including Ranges and Cooktops) | 1 | 12-28-2007 12:20 PM |
