Discuss
sparky
 in
Dishwasher Repair
my dishwasher doesn't seem to dry. I changed the element and still nothing. what now Ads By Google Related Models
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » sparky
  #1 (permalink)
Old 03-03-2011, 07:04 PM
Junior Member
sparky2011 is on a distinguished road
Default sparky
Model Number: fdb2810ldc1   Brand: Frigidaire   Age: 5 - 10 years
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 03-04-2011, 03:37 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for FRIGIDAIRE FDB2810LDC1 Frigidaire/dishwasher | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodin...4495501ena.pdf
I would check the hi-limit thermostat, should be 0 ohms.
__________________
  #3 (permalink)
Old 03-09-2011, 12:07 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by denman View Post
Sparky,
With your multi meter, check the hi limit thermostat for a closed circuit(below 200 dgrs.) like the previous post.
You can program the test mode and the last 90 seconds of the test will send power to the thermostat and element, the element should be warm if you open th door at the end of the test mode(if the control board is operating properly).
Were it me I would perform a "live" voltage test,
You may or may not want to ?
(be extremely careful if you do)
You'd attach one meter lead to a chassis ground. and the meter set to read AC voltage, check each wire/terminal for 120 VAC from the terminal to chassis ground, starting at the red wire on the hi limit thermostat, the other red wire at the thermostat, then the red wire on the element, then the white wire on the element,
With the information from the previous post, and this additional information, you should be able to determine the fault in the heater circuit.
(if there's no voltage on the red wires at the thermostat, you'd have a broken red wire back to the control board, or a bad control board).
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
