Discuss
Wahing Machine in the draining cycle backs-up
 in
Dishwasher Repair
Hello, Ok you probably laugh and say Hey Lady you need a new washer. My dilmena is that I don'
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Wahing Machine in the draining cycle backs-up
  #1 (permalink)
Old 10-21-2007, 08:36 AM
MGray MGray is offline
Junior Member
MGray is on a distinguished road
Default Wahing Machine in the draining cycle backs-up
Model Number: design 2000   Brand: Whirlpool   Age: More than 10 years
Hello,
Ok you probably laugh and say Hey Lady you need a new washer. My dilmena is that I don't know if I need a plumber or a washing machine maintenance or a new washer.
First the washer does not run cold water at all. I checked the hoses and cold water is turned on. Also this is a biggy. When the washing machine fills up everything is fine. When it gets to the cycle of draining, the water now backs up to the toilet in my bathroom. My washer and pipes for the toilet are all on the same side of the house. We took the toilet off and can see when the washer tries to drain it seems to want go back towards the toilet then you will see the water in the drain (on the floor for the toilet) water begin to drop. I will see soap water coming up from the toilet floor drain. Now if you just run faucets in the bathroom and tub water this problem does not occur. It is stemming when the washer is draining. Oy I need help
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-21-2007, 10:29 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Check the screen in the water valve. Remove the cold water hose from the back of the washer and look inside the valve for the screen. It maybe plugged up. Also check the hose for a screen to see if it needs cleaning.
Time to call the plumber in.
__________________
ApplianceJunk.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no draining after washing. luirod563 Washer Repair 4 10-12-2007 09:38 AM
dishwasher draining all the time kevintooley Dishwasher Repair 1 09-19-2007 07:02 PM
front loader not draining distress Washer Repair 1 09-14-2007 03:24 AM
Water Is Draining As It Fills jbgreer Washer Repair 2 09-03-2007 11:52 AM
Washing Machine runs through cycle in two minutes scully27926 Washer Repair 1 08-07-2007 09:28 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
