| » No water pressure |
Model Number: GSD3125F00BB Brand: GE Age: 5 - 10 years
When I start the wash cycle, the water is just dribbling out of the bottom on the inside of the washer. The motor is obviously running, but there's just no pressure. Do I have a faulty pump?
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
I would pull off the inner door panel and look at the wires going to the selector switch, they have had a lot of problems with the switch failing from soap contamination. New Part AP2617405 includes a shield to prevent this.
If ok, feel the water valve while it is filling, should fill for at least 40 seconds, if ok, you have weak water pressure to the valve.
__________________
- Last edited by richappy : 12-26-2008 at 02:55 AM. |
richappy- Thank you for the tip. I pulled the inner panel and the wiring and switch looked good. One thing I noticed- I "cheated" the latch switch so I could run the washer with the door open. Water is coming up through the center assembly, but at the same time water is draining down in the "sump" (don't know proper term). Is that draining function controlled by the timer assembly? Thank you for any replies.
| Display Modes | |
| Not enough water pressure | marshallfla | Dishwasher Repair | 7 | 05-11-2011 04:17 PM |
| Low Water Pressure | Chuck123 | Refrigerator & Freezer Repair | 4 | 10-05-2009 01:08 PM |
| Low water Pressure | Jimh64 | Refrigerator & Freezer Repair | 2 | 07-21-2009 06:08 PM |
| no water pressure on arms | bellhotrod1 | Dishwasher Repair | 0 | 07-15-2009 09:29 AM |
| Motor humming and water comes but blades don't spin (water pressure problem?) | mtheriault3 | Dishwasher Repair | 4 | 01-11-2009 04:18 PM |
