My question is whether to remove & replace the drain pump & motor assembly? The check valve(Flapper) looks distorted, this has to be replaced. When I tested the above, it jitters/vibrates. How to tell if the above unit is bad? Also, the check valve washers used for the drain pump & motor assemblies and the drain exit port the same for both? Can you please verify that drain pump & motor assembly is identical for the GE GSD4610Z00AA as well as for GE GSD4610Z02AA? Waiting for your early reply. Thank you very much. Quaid Johar
