| » GE lower wash arm |
Model Number: ghd6711l15ss Brand: GE Age: 1 - 5 years
I have a 3 year old dishwasher. the dishes weren't getting clean in it. When i inspected it I found the lower arm was not attached. It was floating ande not spraying. How do Iget this atached? Is there an assembly picture you may have?
Quote:
Dirty Dishes, This should be your lower wash arm, Part number: AP3875429 It is a somewhat twist/lock fit. Here are some instructions from the service manual. Lower Spray Arm, Fine Filter, and Inlet Cover Check the holes in spray arm for bits of china, seeds, and other foreign matter. Also check the spray wash arms for rotation. If soil is present, clean fine filter screen. The lower spray wash arm can be removed by gently lifting and rotating it counter clock wise. The nut hub can be removed by rotating it counterclockwise. Caution: Use care to avoid breaking the clip on the hub when removing the main conduit from hub. Note: When installing the fine filter, make sure the drain port of the filter is engaged with the drain for the fine filter.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Lower Wash Arm | janmet@ameritech.net | Dishwasher Repair | 0 | 01-20-2011 06:04 AM |
| lower arm wash | fatboy24 | Dishwasher Repair | 0 | 03-19-2010 03:58 PM |
| Lower Wash Arm | chosen soldier | Dishwasher Repair | 1 | 11-18-2009 04:07 AM |
| Lower Wash Arm Problems | dk52bk55 | Dishwasher Repair | 0 | 01-01-2009 06:12 AM |
| Reattaching lower wash arm | Thomas56 | Dishwasher Repair | 0 | 09-21-2008 08:14 AM |
