Problem with when we press buttons on control panel, we hit NORMAL wash and the Pots/Pans and Quick Rinse come on and washer starts goes thru cycles ok,but not on what we pushed. also just fragments of numbers show up in time display. If I press Cancel Drain washer stops then Nornal wash light comes on and the pots/pans and Quick rinse light goes off and washer drains and everything goes off, meaning lights, washer, and display. I replaced the control board, still does the same thing, so now I'm really confused. Help!!!!!
