Discuss
Top sprayer - no water going to it
 in
Dishwasher Repair
Good morning, Dishwasher drains and fills fine. No leaks. Bottom sprayer spins but slowly and top sprayer does not. No
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Top sprayer - no water going to it
  #1 (permalink)
Old 12-20-2008, 09:48 AM
WDC WDC is offline
Junior Member
WDC is on a distinguished road
Default Top sprayer - no water going to it
Brand: Kitchen Aid   Age: 5 - 10 years
Good morning,
No clogs in sprayer or tubes and water pressure good.
I did notice pump outlet screen was torn some. See attached file. I ordered a new one.
Not sure if this is causing the problem. Is there a solenoid for the upper sprayer or does pressure control it.
Thanks for any help.
Ads By Google
  #2 (permalink)
Old 12-22-2008, 01:58 PM
Junior Member
KRS II is on a distinguished road
Default help
I'm having similar situation, somebody please help
  #3 (permalink)
Old 12-23-2008, 07:08 PM
WDC WDC is offline
Junior Member
Default
Hope this is helpful.
I purchasesd a new pump outlet screen. I noticed it is the identical part (checked numbers on new and old outlet) to the old one except for the following. It is flatter and less bowed.
Also I noticed there are six tiny ports which appear to be part of the motor cover. I think these are tiny water ports I did not notice it in the past. The new pump outlet screen allows them to be more apparent when installed. The old outlet screen covered it with part of the screen.
They were clogged with debris. The inner circle of the pump outlet screen sits on these holes.
After I unclogged these ports and installed the pump outlet screen my upper spinner is working. It could be these tiny ports with debris, or the new/modified pump outlet screen(old one was torn some). Also make sure you install all the pump outlet screen rubbber gaskets.
Tried to explain it the best I could.
If there is any other help you need just reply.
And yes I have a happy wife. Two weeks with no dishwasher is not good.
  #4 (permalink)
Old 12-24-2008, 02:16 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Need model numbers to help.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
top sprayer arm not releasing water wytbeard Dishwasher Repair 0 07-01-2009 01:41 PM
Sprayer arm Motoduc84 Dishwasher Repair 0 06-05-2009 06:05 PM
Bottom sprayer arm wont turn, but top sprayer arm does work chader Dishwasher Repair 0 01-12-2009 07:24 AM
top sprayer arm doesn't work lGrasberger Dishwasher Repair 2 12-25-2007 02:07 AM
Top sprayer not working buh Dishwasher Repair 0 10-24-2007 06:58 PM
