Discuss
Whirlpool Diagnostic Sequence?
 in
Dishwasher Repair
Hi, I have a Whirlpool GU2400XTPB6 with the dreaded "7 LED Flash" problem. Got this with the house
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Diagnostic Sequence?
  #1 (permalink)
Old 12-19-2008, 07:15 PM
RobP RobP is offline
Junior Member
RobP is on a distinguished road
Exclamation Whirlpool Diagnostic Sequence?
Brand: Whirlpool   Age: Less than 1 year
I have a Whirlpool GU2400XTPB6 with the dreaded "7 LED Flash" problem. Got this with the house when new, and (wouldn't you know it) the datasheet is missing from the lower front panel.
I have validated the heater circuit from the control board, through the limit switch, on to the heater element, up to the door switch (I used a small wedge to simulate a door-closed condition to validate the microswitch), and back to the control board. Resistance throughout the circuit is approximately eleven (11) ohms (measured with the board disconnected between the WHT/RED Wire and the WHT wire after the door switch).
First, is eleven ohms reasonable on this circuit? If this is not a solid measurement value, how much current should the heater element draw? I have an ammeter, and know how to use it. I could isolate the heater element and run 120VAC through it for a few seconds to determine current draw.
Second, is there any way I could get the diagnostic sequence from you?
I really don't want to replace a control board & heater if the system sensed a low temp value and went to default.
Thanks!
Rob
  #2 (permalink)
Old 12-19-2008, 08:28 PM
denman denman is online now
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here is your parts breakdown
Model GU2400XTPB6
Here is your tech sheet
https://www.servicematters.com/docs/...%208535451.pdf
Heating element is within spec. Draw would be 120/11= 10.9 amp.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Sequence of operation. kevinlinville76 Oven Repair (including Ranges and Cooktops) 0 12-13-2009 11:39 AM
whirlpool duet gas dryer no heat except in diagnostic mode washerman101 Dryer Repair 0 08-10-2009 02:36 PM
Jenn-Air sequence lights says bd labonte1000 Dishwasher Repair 1 07-08-2008 10:45 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
