Rita G.
#1 Posted : Friday, December 19, 2008 12:06:01 PM(UTC)
Rita G.
will not drain.
checked the filters – found nothing.
plumber said nothing wrong with plumbing.
advice?
misterfixall
#2 Posted : Friday, December 19, 2008 6:22:57 PM(UTC)
misterfixall
are you getting 110 volts to pump?. did you check where drain hose goes into drain pipe ,could be blocked in pipe .
Rita G.
#3 Posted : Saturday, December 20, 2008 4:05:52 AM(UTC)
Rita G.
thank you misterfixall for your reply.
will check it out later & report back.
WDC
#4 Posted : Saturday, December 20, 2008 8:53:11 AM(UTC)
WDC
My dishwasher drained but not fully. Went under the dishwasher, pulled off the rubber hose from near the motor and noticed a blockage between the hose and the tube. Blow through the rubber hose to see of it is clogged.
Rita G.
#5 Posted : Monday, December 22, 2008 9:49:34 AM(UTC)
Rita G.
thank you both for responding.
i am anxious to look underneath & behind the unit.
is there any special procedure to follow to get the bottom panel off?
and since it is surrounded tightly by cabinets, is it safe to just pull the unit straight out?
any safety precautions to take, etc?
