Not draining...check and clean checkvalue found a large piece of glass in diswasher. Motor is running on Cancel/Drain but no water entering the disposal. Ordered a new pump from here. Parts diagram only shows a single screw that attaches pump. Is this true and if so what kind of head does it have (phillips, hex etc)
Ralph
