Here are your parts, includes a wiring diagram.
Replacement parts for mdb9750aw models | AppliancePartsPros.comYou have 3 devices in the water valve circuit,
The control board', the water valve and the float (overflow) switch
Take the kick panel off and check the overflow switch. It should be activated. If not there may be crud in the float assembly which is holding the float up.
The rest of the checking is easiest with a meter.
Check for 120 volts across the water valve when it should be on.
If you have 120 volts then there is a problem with the valve.
Could be the valve is toast.
Could be that the screen filter built into the input side of the valve is clogged.
Remove the valve from the machine and check/clean the screen filter.
Do not permanently remove it as it is there to keep crud out of the valve which could hold it open and cause a flood.
If there is no voltage.
Check for voltage across the valve and float switch combination.
If there is voltage, then double check by measuring across the float switch.
If there is voltage there then the float switch is toast.
If there is no voltage across the valve and float switch combination, then either you have a broken wire from the the control board, a bag connector or the control board is toast.
