Hi, Need guidance on resistance readings (or others) to isolate/determine malfunction. Malfunction: After power interruption. No lights/response from keypad. Constant high-pitched tone from module control assembly (circuit board). Non-typical failure per GE. Board replaced, same condition. Ribbon connector/Touchpad? Turbidity sensor? Transorb? Does this model have one? Door control?" (wrong age selected: older than 5 yrs)
