Discuss
NO water, but has new valve
 in
Dishwasher Repair
Have a Bosch SHE43M02UC/48 with no water coming in. Replaced the water valve and it worked for one week, then
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » NO water, but has new valve
  #1 (permalink)
Old 02-14-2011, 12:56 PM
Junior Member
TimothyH is on a distinguished road
Default NO water, but has new valve
Brand: Bosch   Age: 1 - 5 years
Have a Bosch SHE43M02UC/48 with no water coming in. Replaced the water valve and it worked for one week, then did the same thing. The water and power are both on and it makes noise like it's running. When I start it, it starts making noise immediately, but when it's working properly there is normally a slight delay before I hear anything.
I just tried starting it again, after weeks of it not working, and it started right up, water and all. Any suggestions?
Ads By Google
  #2 (permalink)
Old 02-14-2011, 06:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Timothy,
Remove the toe panel and try to pinpoint the noise at the start time. Is it coming from the main pump or from the drain pump?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-15-2011, 07:40 AM
Junior Member
Default
Gene,
As of last night, the thing seems to be working again, but I don't know for how long this time. The noise on start-up when it wasn't working seemed to come from the right side. I'm not sure which motor is where. It was also slightly louder when this happened and the water was not pumped in.
  #4 (permalink)
Old 02-15-2011, 12:48 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Timothy,
Possible it was some water in the dishwasher base which caused the float switch to shut down the dishwasher and start the drain pump. The drain pump empties out the sump and hoses, not the base. So the drain pump will run until the water leak into the base stops and/or the water in the base evaporates.
__________________
  #5 (permalink)
Old 02-15-2011, 03:02 PM
Junior Member
Default
Thanks, Gene - I'll check it out. Any idea what the best approach is?
  #6 (permalink)
Old 02-15-2011, 03:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Timothy. I don't think you will find anything now because as you said it's working.
__________________
  #7 (permalink)
Old 02-22-2011, 07:35 PM
Junior Member
Default
Quote:
Gene, dishwasher is dead again. How do I go about finding the leak in the base? I'm not sure how to even get started.
Timothy
  #8 (permalink)
Old 02-22-2011, 08:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Timothy,
Remove the bottom panel and try to find the source of the water leak. Check the wash pump and all hoses.
If it would not work then you have to remove the dishwasher from the cabinet and remove the base from the tank. The instructions are attached.
File Type: doc How to remove the base from the tank.doc (549.5 KB, 4 views)
__________________
  #9 (permalink)
Old 02-23-2011, 08:09 AM
Junior Member
Default
Thanks again, Gene.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire leaking water from water inlet valve Swordfish5150 Refrigerator & Freezer Repair 1 01-30-2011 08:16 PM
water dispenser leaks (yes I replaced the water inlet valve, filter, and installed s) david465 Refrigerator & Freezer Repair 4 03-11-2010 04:12 PM
water lines to hook up to the water valve on a kenmore coldspot simonf22 Refrigerator & Freezer Repair 0 12-17-2009 12:16 PM
How Can I replace Water Pipe that is connected from Water Dispenser valve to Dispense Rashmikant Refrigerator & Freezer Repair 0 11-23-2009 03:04 PM
Installing a Water Inlet Valve to copper water line neilkrenz Refrigerator & Freezer Repair 0 09-27-2009 02:50 PM
