The dishwasher lost power in the middle of a cycle. After some research I assumed it was the Control Board which I receive yesterday from Appliance Part Pro. Part#AP2109325 (154320603). I replace it and still have no power or lights on the panel. I checked the Latch Switch prior to ordering the board. The continuity appears OK. I even jumped the wires to be sure. Power is getting to the board through the White wire that connects to the switch. Could the Transformer be bad and power still be received at the White power wire that connects to the switch? thom2 attached the following image(s):
