| » Dishwasher will not clean |
Model Number: 1 Enlarge Photo Accumulator assembly Part Number: AP3609773 made by WHIRLPOOL Brand: Whirlpool Age: 1 - 5 years
When I start I can hear the dishwater fill up but then it will do nothing, and then after a few minutes it will drain, I have checked the hoses and the grinder, all is clear. Does the machine have more than one pump?
Quote:
Pederl, Yes, Some WP dishwashers have a separate drain pump, but they all have a wash motor/pump assembly. I get the impression that the motor never runs, no hum, no nothing, when it should be washing, correct ? If you can get us a proper model number, we'll be more than happy to supply you with as much information as possible. Thanks,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I have a Model# GU1500XTLS3 and the pump motor is 8534942. You are correct that the sump pump will pump the water into and out of the washer but the cycle is silent. I have checked the motor with a meter and I get 5.2 resistance. I should get 0, correct.
Quote:
Pederl, Sounds like you tested the motor winding, you' d have a resistance reading, if you did it correctly. So you're on the right track. Let's try and simplify this. Disconnect the motor wire harness from the wash motor/pump, Program the unit to run and let fill, 1 or 2 minutes after the fill is finished, you need to check for 120 VAC from the purple wire in the harness to chassis ground. if the relay on the control board closes and the wiring is proper,you should have it. That way we can isolate where the problem is, the control or the wash motor.
__________________
Quote:
If you have the voltage on the purple wire, your control board is working, your wire is good, and you'd have a bad motor. No voltage on the wire terminal would indicate a broken wire or a bad K1 relay on the control board. And once you determine where the voltage is or isn't you can determine which way / part you will need.
__________________
I'm sorry, I do not have a purple wire. If I start the dishwasher and wait for the cycle to start and I have disconnected the connector for the motor, can I check the voltage there (put one probe on the ground and the other in the connector?
Quote:
My diagram shows a purple wire, you may have a red/black ? But yes, you can check the wire coming from the relay to the motor, to chassis ground for 120 VAC. The readings and results should be the same.
__________________
Yes, you have to unplug the wire harness going to the motor, re apply power to the unit and start a cycle, let it fill and wait 60 to 90 seconds. Then do the voltage test, on the wires in the harness, not the motor.
__________________
| Display Modes | |
| LG Dishwasher will not clean | kelli | Dishwasher Repair | 0 | 06-16-2009 05:50 PM |
| Dishwasher does not clean | jlp7534 | Dishwasher Repair | 2 | 03-15-2009 12:34 PM |
| Dishwasher won't clean | drodder52 | Dishwasher Repair | 0 | 12-09-2008 04:00 PM |
| dishwasher does not clean or dry well | aburns24 | Dishwasher Repair | 1 | 11-06-2008 01:29 PM |
| GE dishwasher won't clean | gayleinsw | Dishwasher Repair | 1 | 05-23-2008 01:52 AM |
