Discuss
Bosch dishwasher control panels or buttons?
 in
Dishwasher Repair
My dishwasher has push button controls, all of which still work except for the Off/On button. It simply will not
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher control panels or buttons?
  #1 (permalink)
Old 12-11-2008, 07:34 PM
Junior Member
laureldesigns is on a distinguished road
Post Bosch dishwasher control panels or buttons?
Model Number: SMU4092UC/14   Brand: Bosch   Age: More than 10 years
My dishwasher has push button controls, all of which still work except for the Off/On button. It simply will not engage. Do I need to replace the whole control panel, or just the one button that does not work? Is it easier for a novice repair person perosn to replace the panel or open up the existing one and replace the button? Help!
Related Models
Bosch SMU4096 UC/14 (FD -7902)
Bosch SMU7052 UC/09 (FD 7307-7504)
Bosch SMU7052 UC/09 (FD 7505-7506)
Bosch SMU7052 UC/09 (FD 7507-7902)
Bosch SMU7052 UC/14 (FD 7402-7902)
Bosch SMU7052 UC/14 (FD 7507-7902)
Bosch SMU7052 US/02 (FD 7106-7308)
Bosch SMU7052 US/09 (FD 7210-)
Bosch SMU7056 UC/09 (FD 7307-7504)
Bosch SMU7056 UC/09 (FD 7505-7506)
Bosch SMU7056 UC/09 (FD 7507-7902)
Bosch SMU7056 UC/14 (FD 7402-7902)
Bosch SMU7056 UC/14 (FD 7507-7902)
Bosch SMU7056 US/02 (FD 7106-7308)
Bosch SMU7056 US/09 (FD 7210-)
 SMV9165BC MWAVE- MOUNTED OVER RANGE/WO
 SMV9165SC MWAVE- MOUNTED OVER RANGE/WO
Thermador SMW272B BUILT-IN OVEN
Thermador SMW272P BUILT-IN OVEN
Thermador SMW272S BUILT-IN OVEN
Thermador SMW272W BUILT-IN OVEN
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Amana SNAC-700.A COMMERCIAL MICROWAVES
Amana SNAC-700.B COMMERCIAL MICROWAVES
Amana SNAC-7TP.A COMMERCIAL MICROWAVES
Amana SNAC-7TP.B COMMERCIAL MICROWAVES
Amana SNAC700 COMMERCIAL MICROWAVES
Amana SNAC700.C COMMERCIAL MICROWAVES
Amana SNAC700.D COMMERCIAL MICROWAVES
Amana SNAC7TP.003 COMMERCIAL MICROWAVES
Amana SNAC7TP.004 COMMERCIAL MICROWAVES
Amana SNAC7TP.005 COMMERCIAL MICROWAVES
Amana SNAC8LW COMMERCIAL MICROWAVES
Amana SNE26AA RANGE - ELECTRIC STD DELAWARE
Amana SNE26CB RANGE- S/C S/I DDRAFT GAS
Amana SNE26CB RANGE - ELECTRIC STD DELAWARE
Amana SNE26ZZ RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA0 RANGE- S/I STD GAS
Amana SNK26AA5 RANGE- S/I STD GAS
Amana SNK26CB RANGE- S/C S/I DDRAFT GAS
Amana SNK26CB0 RANGE- S/I STD GAS
Amana SNK26CB5 RANGE- S/I STD GAS
Amana SNK26FS RANGE- S/C S/I DDRAFT GAS
Amana SNK26FS0 RANGE- S/I STD GAS
Amana SNK26FS5 RANGE- S/I STD GAS
Amana SNP26AA RANGE- S/I STD GAS
Amana SNP26AA0 RANGE- S/I STD GAS
Amana SNP26AA5 RANGE- S/I STD GAS
Amana SNP26AH0 RANGE- S/I STD GAS
Amana SNP26CB RANGE- S/I STD GAS
Amana SNP26CB0 RANGE- S/I STD GAS
Amana SNP26CB5 RANGE- S/I STD GAS
Amana SNP26ZZ RANGE- S/I STD GAS
Amana SNP26ZZ0 RANGE- S/I STD GAS
Whirlpool SNPA-0 Pasta Maker Stand Mixer Attachment
Amana SP17A REF - SXS/I&W
Amana SP17A-A REF - SXS/I&W
Amana SP17A-AG REF - SXS/I&W
Amana SP17A-C REF - SXS/I&W
Amana SP17G REF - SXS/I&W
Amana SP17G-A REF - SXS/I&W
Amana SP17G-AG REF - SXS/I&W
  #2 (permalink)
Old 12-12-2008, 03:59 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The "on-off" switch is a part of the selector switch (push-button switch). Unfortunately this part is no longer available. Probably it's time for a new dishwasher.
Here are the break down diagrams for the Bosch dishwasher Model SMU4092 UC/14 (FD -7902)
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-12-2008, 07:07 PM
Junior Member
Default
Thank you for your help. If the individual part is not available, can the whole control panel be replaced? even at 140.00 that's cheaper than a new dishwasher. Thanks for your time.
  #4 (permalink)
Old 12-12-2008, 10:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Which part did you call "control panel"?
__________________
  #5 (permalink)
Old 01-01-2009, 03:45 PM
Junior Member
schentow is on a distinguished road
Smile broken wire not a broken switch
Quote:
I thought I had the same problem with the power switch. It did not seem to engage. I would have ordered a new one if it had been available. I took the old switch out and discovered it was working fine. The power switch (double pole) opens and closes both the hot and the common connection. What I discovered was that the black wire between the junction box located below the door in the front of the dishwasher and the power switch was broken. It is a solid copper wire and flexes each time the door is opened. I replaced the wire and the switch and the dishwasher now works fine. Give it a try and good luck! I guess I will have to keep using my old dishwasher! Steve
  #6 (permalink)
Old 02-18-2009, 11:46 PM
Junior Member
kilohu is on a distinguished road
Default
Thanks Steve. I had the same problem and followed your advice. It worked and saved me $$ from buying a new one!
Joan
  #7 (permalink)
Old 12-19-2010, 04:34 AM
Junior Member
phelanm2 is on a distinguished road
Default
This sounds exactly like the problem I am having. How difficult is it to do yourself? I am not sure how to remove the switch (does it need to be the entire control panel) and whether I need a particular wire.
Can you provide any more information?
Thanks so much
Quote:
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Info on removing control & service panels aretroman Washer Repair 1 10-17-2009 02:57 PM
GE Spacemaker XL1800 control panels locks up usd777 Microwave Repair 1 04-07-2009 02:40 PM
Bosch dishwasher control or buttons? rfjoinery Dishwasher Repair 3 03-09-2009 05:59 PM
Whirlpool GU980SCGB and GU940SCGB - same control panels? fredjudd Dishwasher Repair 1 07-27-2008 05:57 PM
