| » Bosch Circulating Pump Problem |
Model Number: SHV4303 Brand: Bosch Age: 5 - 10 years
DW stopped working and I found water in bottom. After checking that float switch and level switch were OK, I saw a forum entry about a "stuck" circulating pump. After I removed the RH panel (2 screws at front of DW, then lift off) I was able to see the pump motor's fan. I tried to rotate the motor fan with a screwdriver blade and felt some resistance. Then with just a little nudge it easily broke free. I put everything back together and the DW worked perfectly.
| Display Modes | |
| Bosch SHU6806UC/12 - Not circulating water well | wmako | Dishwasher Repair | 7 | 08-18-2010 07:29 AM |
| Replaced circulating pump, now wash cycle is less, water is not heated up. | tobygirl | Dishwasher Repair | 0 | 05-04-2010 09:49 AM |
| Bosch SHE44C Dishwasher never stops circulating | Fixtime | Dishwasher Repair | 8 | 01-06-2010 08:09 PM |
| replacing a Bosch circulating pump | MillenniumBuilding | Dishwasher Repair | 0 | 10-22-2009 08:07 AM |
| Bosch dishwasher pump problem | Bennyboy42 | Dishwasher Repair | 1 | 05-01-2008 06:03 PM |
