Discuss
No Water in Kenmore Elite
 in
Dishwasher Repair
I have Kenmore Elite Dishwasher that is not gettting any water. I start the cycle and all lights work and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » No Water in Kenmore Elite
  #1 (permalink)
Old 02-08-2011, 12:25 PM
Junior Member
kathon526 is on a distinguished road
Default No Water in Kenmore Elite
Brand: Kenmore   Age: 1 - 5 years
I have Kenmore Elite Dishwasher that is not gettting any water. I start the cycle and all lights work and buttons work to change cycle. But the water does not fill. I checked the water fill valve and float switch. Both work. I checked continuity - fine. I put 120V on the inlet of float valve and water came on & off from myself raising / lowering the float - it works. I don't have schematic and can't find model number. I think it is the board model 974483 or new model 8530929. But since I don't have schematic don't know if there is anything else in series for the 120 to activate fill valve. The 120VAC is getting to board. There are three relay's on the control board. Don't know which is for fill valve. Any ideas? Is there something before the float but after the computer board that could stop the voltage? Thanks
  #2 (permalink)
Old 02-08-2011, 12:59 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Chances are that you have a bad board. The components involved in the fill cycle are the door switch, fill valve, and the overflow switch. Check to make sure your electrical hook-up athe dishwasher is sound. Check especially for a loose or disconnected neutral or ground wire.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Calypso does not fill up with water kenmore_owner Washer Repair 0 09-01-2010 05:08 PM
Kenmore Elite Calypso does not fill up with water kenmore_owner Washer Repair 0 08-25-2010 07:46 PM
Kenmore Elite Dishwasher water leak davedishwasher Dishwasher Repair 0 07-15-2010 09:21 AM
Kenmore Elite no water in door dannasoft Refrigerator & Freezer Repair 1 06-02-2009 02:25 PM
Kenmore Elite won't fill with water packersphan Dishwasher Repair 11 04-04-2009 06:23 PM
