Discuss
Whirlpool dishwasher disassembly
 in
Dishwasher Repair
My machine is clogged with hard water deposits. I am trying to disassemble the lower arm so I clean the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool dishwasher disassembly
  #1 (permalink)
Old 01-29-2011, 11:30 AM
Junior Member
klc4570 is on a distinguished road
Default Whirlpool dishwasher disassembly
Model Number: GU2700XTSS1   Brand: Whirlpool   Age: 1 - 5 years
My machine is clogged with hard water deposits. I am trying to disassemble the lower arm so I clean the arm, screen and everything else down there, but the hub, which does appear to have threads, just spins, and I can't figure out how to get this lower spray arm assembly off.
It turns, but does not seem to be coming off. Any hints?
Thanks a lot!
Ads By Google
Related Models
Whirlpool GU2700XTSS1 Undercounter Dishwasher
Whirlpool GU2700XTST0 Undercounter Dishwasher
Whirlpool GU2700XTST1 Undercounter Dishwasher
Whirlpool GU2700XTSY0 Undercounter Dishwasher
Whirlpool GU2700XTSY1 Undercounter Dishwasher
Whirlpool GU3200XTPB0 Undercounter Dishwasher
Whirlpool GU3200XTPB1 Undercounter Dishwasher
Whirlpool GU3200XTPB3 Undercounter Dishwasher
Whirlpool GU3200XTPB4 Undercounter Dishwasher
Whirlpool GU3200XTPB5 Undercounter Dishwasher
Whirlpool GU3200XTPQ0 Undercounter Dishwasher
Whirlpool GU3200XTPQ1 Undercounter Dishwasher
Whirlpool GU3200XTPQ3 Undercounter Dishwasher
Whirlpool GU3200XTPQ4 Undercounter Dishwasher
Whirlpool GU3200XTPQ5 Undercounter Dishwasher
Whirlpool GU3200XTPS0 Undercounter Dishwasher
Whirlpool GU3200XTPS1 Undercounter Dishwasher
Whirlpool GU3200XTPS3 Undercounter Dishwasher
Whirlpool GU3200XTPS4 Undercounter Dishwasher
Whirlpool GU3200XTPS5 Undercounter Dishwasher
Whirlpool GU3200XTSB0 Undercounter Dishwasher
Whirlpool GU3200XTSB1 Undercounter Dishwasher
Whirlpool GU3200XTSB2 Undercounter Dishwasher
Whirlpool GU3200XTSQ0 Undercounter Dishwasher
Whirlpool GU3200XTSQ1 Undercounter Dishwasher
Whirlpool GU3200XTSQ2 Undercounter Dishwasher
Whirlpool GU3200XTSS0 Undercounter Dishwasher
Whirlpool GU3200XTSS1 Undercounter Dishwasher
Whirlpool GU3200XTSS2 Undercounter Dishwasher
Whirlpool GU3600XTRB0 Undercounter Dishwasher
Whirlpool GU3600XTRB1 Undercounter Dishwasher
Whirlpool GU3600XTRQ0 Undercounter Dishwasher
Whirlpool GU3600XTRQ1 Undercounter Dishwasher
Whirlpool GU3600XTRY0 Undercounter Dishwasher
Whirlpool GU3600XTRY1 Undercounter Dishwasher
Whirlpool GU3600XTSB0 Undercounter Dishwasher
Whirlpool GU3600XTSB1 Undercounter Dishwasher
Whirlpool GU3600XTSB2 Undercounter Dishwasher
Whirlpool GU3600XTSQ0 Undercounter Dishwasher
Whirlpool GU3600XTSQ1 Undercounter Dishwasher
Whirlpool GU3600XTSQ2 Undercounter Dishwasher
Whirlpool GU3600XTSY0 Undercounter Dishwasher
Whirlpool GU3600XTSY1 Undercounter Dishwasher
Whirlpool GU3600XTSY2 Undercounter Dishwasher
Whirlpool GU630XTLQ0 Undercounter Dishwasher
Whirlpool GU630XTLQ1 Undercounter Dishwasher
Whirlpool GU640XTLQ0 Undercounter Dishwasher
Whirlpool GU640XTLQ1 Undercounter Dishwasher
Whirlpool GU940SCGB0
Whirlpool GU940SCGB1
Whirlpool GU940SCGB2
Whirlpool GU940SCGB3
Whirlpool GU940SCGQ0
Whirlpool GU940SCGQ1
Whirlpool GU940SCGQ2
Whirlpool GU940SCGQ3
Whirlpool GU940SCGT3
Whirlpool GU940SCGZ0
Whirlpool GU940SCGZ1
Whirlpool GU940SCGZ2
Whirlpool GU940SCGZ3
Whirlpool GU960SCGB0
Whirlpool GU960SCGQ0
Whirlpool GU980QPDB0
Whirlpool GU980QPDQ0
Whirlpool GU980QPDZ0
Whirlpool GU980SCGB0
Whirlpool GU980SCGB1
Whirlpool GU980SCGB2
Whirlpool GU980SCGB3
Whirlpool GU980SCGQ0
Whirlpool GU980SCGQ1
Whirlpool GU980SCGQ2
Whirlpool GU980SCGQ3
Whirlpool GU980SCGS1
Whirlpool GU980SCGS2
Whirlpool GU980SCGS3
Whirlpool GU980SCGT2
Whirlpool GU980SCGT3
Whirlpool GU980SCGZ0
Whirlpool GU980SCGZ1
Whirlpool GU980SCGZ2
Maytag GV1110PRW Range - F/s Std Gas
International GV1226NXEW Freezer - Vertical
International GV1726NXEW Freezer - Vertical
Hoover GV3177WUA Range - F/s Std Gas
Hoover GV3177WUA5 Range - F/s Std Gas
Hoover GV3177WUW Range - F/s Std Gas
Hoover GV3177WUW5 Range - F/s Std Gas
Maytag GV3277XUA Range - F/s Std Gas
Maytag GV3277XUW Range - F/s Std Gas
Hoover GV3531WUA Range - F/s Std Ele
Hoover GV3531WUW Range - F/s Std Ele
Whirlpool GVW9959KL0
Whirlpool GVW9959KL1
Whirlpool GVW9959KL2
Whirlpool GVW9959KL3 Automatic Washer
Whirlpool GVW9959KQ0
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
  #2 (permalink)
Old 01-30-2011, 01:32 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is a manual, although it is not for your given model number, I think the pump is the same.
https://secured.whirlpool.com/Servic...LE/8178022.pdf
If the water is very hard you may want to give the unit a de-liming every once in a while.
Add about a quart of vinegar and let it sit for an hour or so.
Then let it fill and run for a minute then again let it sit for an hour or so. Do this several times then let it finish the cycle.
They also make a dishwasher cleaner that does the same thing, just more expensive. It is usually oxalic acid.
Dishwasher Cleaners - Order Now, Same Day Shipping
__________________
  #3 (permalink)
Old 01-30-2011, 08:57 PM
Junior Member
Default Thanks!
Thank you--I appreciate it!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Dryer Disassembly JNagarya Dryer Repair 10 06-27-2011 06:15 AM
disassembly Christopherk Washer Repair 0 11-16-2010 11:43 AM
Need help with disassembly of GE dishwasher Phydeauxman Dishwasher Repair 0 07-17-2010 04:24 AM
disassembly andymu Washer Repair 3 10-03-2009 10:07 AM
Disassembly wstronks Dryer Repair 0 04-25-2009 06:25 AM
