I had a broken door handle and purchased AP4264081 (the whole assembly). The install was fairly straight forward. The problem I have now is that the door doesn't close quite as tight as it used to and it leaks a bit. Is there an adjustment for this part? I'm thinking I need to get the door about 1/8" tighter. Could it just be a defective part?
The leak seems to be coming from the top corners.
