dishwasher will not start up. it just flashes for a while then goes blank. i tried to run field service test but it does not respond, just flashes then goes blank. it will go thru sales floor demo test and keeps counting down with all lights flashing on and off until i take power away. i do believe handle was broke but not sure if related, both tabs broke when opening up. could the control board be bad or motor or? i would appreciate anyones thoughts thanks
