Discuss
GE Profile dishwasher won't drain completely
 in
Dishwasher Repair
I had the same problem. The dishwasher would run, and at theend of the cycle there was water still inside
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Profile dishwasher won't drain completely
  #31 (permalink)
Old 11-14-2012, 04:02 PM
Junior Member
MkBrennanMD is on a distinguished road
Default
I had the same problem. The dishwasher would run, and at theend of the cycle there was water still inside the machine. I'm not an applianceexpert, but I just went through some troubleshooting.
Turn the power off, pull the unit out, and disconnect all the hoses. Get some towels because water will start leaking out of the bottom. In my case, I removed all the hoses, including the one that connected to the disposal. I blew through the ends of each hose, and right away I found one hose that was obstructed .This stuff builds up over time, almost like someone's artery, and once clogged, your best bet is to throw it out, and get a new hose. Its a cheap solution, and is usually the cause.
Your problem sounds identical to mine...so see if my video helps, cause I've gotten feedback from others who found it useful.
https://www.youtube.com/watch?v=u7uaA2NZKl0
Ads By Google
__________________
All Appliances I fix, Plus Humans
  #32 (permalink)
Old 01-04-2013, 07:06 PM
Junior Member
WaldoDog is on a distinguished road
Default
Quote:
Originally Posted by abadfish66 View Post
Now you need to take off the white nut that is above the fine filter, remove the fine filter. Then the hub that has the spray tube attached to it, turn it to the right a bit and pull off that tube that runs up the back wall. Pull off the plastic screen and there is your sump. There is an insert in the sump that that screen clipped to, squeeze that and pull up, and clean it. now stick your hand down in the sump, and pull out whatever it is that is clogging the drain hole.
Very helpful to me also, but I cannot get the plastic liner out of the sump hole, even with squeezing it and pulling with hands and prying with screwdriver. My goal is to get the flat metal screen off the floor of the dishwasher in order to clean the gunk off of it, but the sump liner has a lip that holds down the screen around it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Dishwasher will not drain completely 2bluesuz Dishwasher Repair 6 03-02-2012 04:57 AM
Dishwasher doesn't drain completely melindac Dishwasher Repair 11 03-24-2011 07:24 PM
GE Profile Dishwasher Not Draining Completely Thomas00000 Dishwasher Repair 2 02-24-2010 08:50 AM
GE Profile won't drain completely? coy Dishwasher Repair 8 12-26-2009 03:05 PM
GE Dishwasher won't completely drain patrick0525 Dishwasher Repair 6 10-16-2009 03:41 AM
