| » GE Profile dishwasher won't drain completely |
Not sure if anyone is actively reading/replying...but my GE d/w also has the 'doesnt drain on last cycle' issue.
I opened up the motor, cleaned up pipes, anything i could reach to - didnt find major trash, just little bit. On the impeller, i saw the valves plastic had 3 broken grooves; not sure if that causes any problems. (the #429 in the image at Model GSD4030Z02WW ). What could possibly be an issue? Do i need to open front door panel? Thanks Ads By Google |
Enthu112
I cannot see your link. I would start a new thread using "Post New Topic" be sure to include the model number and make. If you want to refer to a parts picture look it up on AppliancePartsPros and include that link.
__________________
Its #429 at Motor - pump mechanism replacement parts for General Electric GSD4030Z02WW Dishwasher | AppliancePartsPros.com
I hope you can see this link. |
i have a GE dishwasher and it suddenly will not drain completly. I pulled it out from its space and completly cleaned all the hoses. I made sure i could easily blow air through all the drain hoses all the way through back to both the sink and dishwasher itself.
Not sure why, but it will not drain 100%. Everything else works fine on the dishwasher |
steve138martin
You may want to start a new thread using Post New Topic. Please include the model number. Many GE's have a Piston & Nut Assembly at the back under the screened cover. If this does not seal correctly during drain then the unit will leave extra water in the tub.
__________________
Quote:
ok i lifted and spun and it doesn't come out. how hard am i supose to be lifting and i am assuming i am turning counter clockwise looking down at the spinner thingy aka spray arm, i think. |
derfman
Start a new thread using post new topic at the start of this forum section. Add the make and model number as well as the problem you are having and perhaps someone can help you with your unit. It is hard to help without a model number.
__________________
| Display Modes | |
| GE Profile Dishwasher will not drain completely | 2bluesuz | Dishwasher Repair | 6 | 03-02-2012 04:57 AM |
| Dishwasher doesn't drain completely | melindac | Dishwasher Repair | 11 | 03-24-2011 07:24 PM |
| GE Profile Dishwasher Not Draining Completely | Thomas00000 | Dishwasher Repair | 2 | 02-24-2010 08:50 AM |
| GE Profile won't drain completely? | coy | Dishwasher Repair | 8 | 12-26-2009 03:05 PM |
| GE Dishwasher won't completely drain | patrick0525 | Dishwasher Repair | 6 | 10-16-2009 03:41 AM |
