AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
kitchenaid dishwasher not working light just flashes
kitchenaid dishwasher does not work at all. This model has the hidden controls, when I enter a cycle nothing happens, the flashing green light next to the word clean just flashes continually, it flashes 7 times pauses then 7 more times and so on any help would be appreciated walter
Try to reset the control by pressing the following option keys while the dishwasher is inactive: High Temp (power scour) - Air Dry (No heat dry or Energy saver dry) - High Temp - Air Dry. Exit it by opening the door. If it would not solve the problem and the tub of your dishwasher is stainless still, replace the heating element assembly which includes the new control board. If the tub is plastic, post it and we will proceed with the instructions. - The heating element assembly Part number: AP3841139
Dishwasher Repair
