I have a 3 year old Matag dishwasher that no matter what button i press it keeps going back into "Rinse Only" and that is all it does. I turned off the power to it for 5 minutes hoping it would reset. It didnt. I only use it once a week, so its not from overuse. Strange thing is it worked fine before the Tech came in for the recall repair last year. Any suggestions? Model # mbdtt60awb
THIS FORUM IS DEAD!!!!!!! |
If it is the Rinse Only button shorted. What part do I need to replace? thanks for the help.
Take a look in the parts, it is Item 1 in Section 1 (panel).
Not sure if you left a digit or 2 off the end of your model number so check that first before looking up the part. |
