Discuss
dishwasher wash pump will not pump
 in
Dishwasher Repair
Hi, the dishwasher fills with water OK. Then there is a faint hum and it does not go into the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher wash pump will not pump
  #1 (permalink)
Old 01-18-2011, 09:19 AM
Junior Member
streetguy is on a distinguished road
Default dishwasher wash pump will not pump
Model Number: GU2700XTSTO   Brand: Whirlpool   Age: 1 - 5 years
Hi, the dishwasher fills with water OK. Then there is a faint hum and it does not go into the wash cycle. The little time indicator just moves around and around. When I cancel, it drains fine--the motor pumps it out.
I checked the spray arm and food grinder. All seem OK. Also I was able to turn the blade on the food grinder. It turned easily in one direction, but I had trouble turning it in the opposite direction. (It may just be spinning on shaft--I don't know.)
Ideas???
Ads By Google
Related Models
Whirlpool GU2700XTSY0 Undercounter Dishwasher
Whirlpool GU2700XTSY1 Undercounter Dishwasher
Whirlpool GU3200XTPB0 Undercounter Dishwasher
Whirlpool GU3200XTPB1 Undercounter Dishwasher
Whirlpool GU3200XTPB3 Undercounter Dishwasher
Whirlpool GU3200XTPB4 Undercounter Dishwasher
Whirlpool GU3200XTPB5 Undercounter Dishwasher
Whirlpool GU3200XTPQ0 Undercounter Dishwasher
Whirlpool GU3200XTPQ1 Undercounter Dishwasher
Whirlpool GU3200XTPQ3 Undercounter Dishwasher
Whirlpool GU3200XTPQ4 Undercounter Dishwasher
Whirlpool GU3200XTPQ5 Undercounter Dishwasher
Whirlpool GU3200XTPS0 Undercounter Dishwasher
Whirlpool GU3200XTPS1 Undercounter Dishwasher
Whirlpool GU3200XTPS3 Undercounter Dishwasher
Whirlpool GU3200XTPS4 Undercounter Dishwasher
Whirlpool GU3200XTPS5 Undercounter Dishwasher
Whirlpool GU3200XTSB0 Undercounter Dishwasher
Whirlpool GU3200XTSB1 Undercounter Dishwasher
Whirlpool GU3200XTSB2 Undercounter Dishwasher
Whirlpool GU3200XTSQ0 Undercounter Dishwasher
Whirlpool GU3200XTSQ1 Undercounter Dishwasher
Whirlpool GU3200XTSQ2 Undercounter Dishwasher
Whirlpool GU3200XTSS0 Undercounter Dishwasher
Whirlpool GU3200XTSS1 Undercounter Dishwasher
Whirlpool GU3200XTSS2 Undercounter Dishwasher
Whirlpool GU3600XTRB0 Undercounter Dishwasher
Whirlpool GU3600XTRB1 Undercounter Dishwasher
Whirlpool GU3600XTRQ0 Undercounter Dishwasher
Whirlpool GU3600XTRQ1 Undercounter Dishwasher
Whirlpool GU3600XTRY0 Undercounter Dishwasher
Whirlpool GU3600XTRY1 Undercounter Dishwasher
Whirlpool GU3600XTSB0 Undercounter Dishwasher
Whirlpool GU3600XTSB1 Undercounter Dishwasher
Whirlpool GU3600XTSB2 Undercounter Dishwasher
Whirlpool GU3600XTSQ0 Undercounter Dishwasher
Whirlpool GU3600XTSQ1 Undercounter Dishwasher
Whirlpool GU3600XTSQ2 Undercounter Dishwasher
Whirlpool GU3600XTSY0 Undercounter Dishwasher
Whirlpool GU3600XTSY1 Undercounter Dishwasher
Whirlpool GU3600XTSY2 Undercounter Dishwasher
Whirlpool GU630XTLQ0 Undercounter Dishwasher
Whirlpool GU630XTLQ1 Undercounter Dishwasher
Whirlpool GU640XTLQ0 Undercounter Dishwasher
Whirlpool GU640XTLQ1 Undercounter Dishwasher
Whirlpool GU940SCGB0
Whirlpool GU940SCGB1
Whirlpool GU940SCGB2
Whirlpool GU940SCGB3
Whirlpool GU940SCGQ0
Whirlpool GU940SCGQ1
Whirlpool GU940SCGQ2
Whirlpool GU940SCGQ3
Whirlpool GU940SCGT3
Whirlpool GU940SCGZ0
Whirlpool GU940SCGZ1
Whirlpool GU940SCGZ2
Whirlpool GU940SCGZ3
Whirlpool GU960SCGB0
Whirlpool GU960SCGQ0
Whirlpool GU980QPDB0
Whirlpool GU980QPDQ0
Whirlpool GU980QPDZ0
Whirlpool GU980SCGB0
Whirlpool GU980SCGB1
Whirlpool GU980SCGB2
Whirlpool GU980SCGB3
Whirlpool GU980SCGQ0
Whirlpool GU980SCGQ1
Whirlpool GU980SCGQ2
Whirlpool GU980SCGQ3
Whirlpool GU980SCGS1
Whirlpool GU980SCGS2
Whirlpool GU980SCGS3
Whirlpool GU980SCGT2
Whirlpool GU980SCGT3
Whirlpool GU980SCGZ0
Whirlpool GU980SCGZ1
Whirlpool GU980SCGZ2
Maytag GV1110PRW Range - F/s Std Gas
International GV1226NXEW Freezer - Vertical
International GV1726NXEW Freezer - Vertical
Hoover GV3177WUA Range - F/s Std Gas
Hoover GV3177WUA5 Range - F/s Std Gas
Hoover GV3177WUW Range - F/s Std Gas
Hoover GV3177WUW5 Range - F/s Std Gas
Maytag GV3277XUA Range - F/s Std Gas
Maytag GV3277XUW Range - F/s Std Gas
Hoover GV3531WUA Range - F/s Std Ele
Hoover GV3531WUW Range - F/s Std Ele
Whirlpool GVW9959KL0
Whirlpool GVW9959KL1
Whirlpool GVW9959KL2
Whirlpool GVW9959KL3 Automatic Washer
Whirlpool GVW9959KQ0
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
  #2 (permalink)
Old 01-19-2011, 08:13 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Ideas???
Streetguy,
That style dishwasher has a single direction motor, and a separate drain pump(that's why it will drain but not wash).
You should check for 120 VAC to the pump motor from the control board.
( Blue wire to the motor to chassis ground, when the motor should be in the wash mode). You'll need a multi meter to do the test.
Based on your post, you may have something stuck in the impeller assembly,
you may need to remove the motor from the pump housing and check,
Removing the Wash Motor
1. Remove the bolt securing the wash
motor and drip shield in place on the pump
assembly.
2. Once the bolt and drip shield are removed,
turn the wash motor until it stops (approximately
¼ turn).
3. Pull the motor straight back from the sump
assembly. Some effort may be necessary
to dislodge the motor. The volute will remain
attached to the motor.
NOTE:
When reinstalling the wash motor and
volute, do not pinch the volute seal between the
volute and sump. Use a small amount of rinse
aid on the volute seal to help installation.
Fig. 3-17
NOTE:
When reinstalling the sump assembly,
align the locator key with the corresponding
slot in the tub opening.
While you have the motor out, you should check the motor windings resistance, with a multi meter
( the wires that attach to the motor)
Blue to yellow wires should read 6 to 10 ohms resistance
Blue to purple wires should read 3 to 7 ohms resistance
Once your checks and repairs are made and the pump reinstalled,
You should be OK.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Dishwasher - Wash Pump Replace Dan Barnes Dishwasher Repair 1 12-12-2010 06:25 AM
Wash and Rinse water does not pump out goodohman Washer Repair 3 10-24-2010 11:51 AM
replaced motor & pump still doesn't wash russtodd Dishwasher Repair 4 04-17-2009 12:23 PM
Washer not pumping at the end of wash but will pump on spin and lite wash. rathbonr Washer Repair 0 07-16-2008 11:45 AM
