Discuss
Bosch Dishwasher Stuck on 2H
 in
Dishwasher Repair
Do you need tools to remove the plastic face plate? Do you have to remove any of the screws? Do
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dishwasher Stuck on 2H
  #11 (permalink)
Old 04-26-2009, 10:00 AM
paulmnick paulmnick is offline
Junior Member
paulmnick is on a distinguished road
Default face plate of the front of the dishwasher to install control module
Do you need tools to remove the plastic face plate? Do you have to remove any of the screws? Do you have to remove the front of the door?
I can't figure out where the pressure points are to get it off?
  #12 (permalink)
Old 05-29-2009, 12:36 AM
Jon R Seattle Jon R Seattle is offline
Junior Member
Jon R Seattle is on a distinguished road
Default
It's important to note that, after soldering the bad heater relay connection on the circuit board and reinstalling the control module, you will still initially get a "2H" indication when you start the machine. If you have actually fixed the heater circuit, the indication will clear 15 or 20 minutes later in the cycle when the water reaches full temperature (150?). Then the indication will return to normal. As the Bosch person wrote above, if you open the dishwasher and get a face full of steam at this point, you have fixed the heater circuit.
Also, I just had to solder mine, and it has the 10 amp relay, so the 10 amp relay does not solve the problem. The problem appears to be the board connection sizing, not the relay itself.
  #13 (permalink)
Old 07-08-2009, 07:57 AM
scottthowe@aol.com scottthowe@aol.com is offline
Junior Member
scottthowe@aol.com is on a distinguished road
Default
I have a SHU5316UC/UC12 that must be about 7 years old. Got the 2H problem, got the same old vinegar and temp and authorized dealer song and dance from Bosch when I asked if any instructions are available for replacing the control unit. Tried the vinegar thing with no change. Ordered the AP2802870 (266746) unit from AppliancePartsPros.com, got it a few days later, works perfect. To replace the unit, I used a star (Torx) wrench to remove almost all of the screws in the back of the door (left 4 that look like they may be door hinge screws at the bottom). The big panel may fall to the floor, so careful. The new unit includes both boards and the plastic case, so it's just unplug the old, plug in the new. Don't force the old one out - find a few parts of the plastic case that act as clips and release them. Note - I first tried to just remove the top front door panel, but couldn't get it to re-attach to the bottom front door panel until I removed it too.
New update 7/22/09. I actually have two of these - the original owners liked to entertain and put two of these in the kitchen. The first one had the 2H problem a couple of months ago, though I didn't fix it until recently. Now, the other one has developed the same problem. Not going to try the fix-it-with-solder route. Tried the vinegar thing again, and it got rid of the 2H, but it still ran way too long the next time. I just ordered another control unit. Unbelievable.
  #14 (permalink)
Old 07-10-2009, 09:10 PM
tbirkland tbirkland is offline
Junior Member
tbirkland is on a distinguished road
Default 2H Again - Bosch Model SHU6805UC
My model SHU6805UC had the control module replaced 4 years ago and the unit is now almost 10 years old. Now the 2H message appears and the unit takes several hours to get down to 1 and just stalls with water and soap in the bottom of the tub. Pushing "Scrub Wash & Delicate Economy" will make it drain and display CL. This unit cost close to $1,000 new, wondering if I should fix it or just buy a new unit? If I can fix it by installing a $150 part great.
  #15 (permalink)
Old 07-13-2009, 05:12 PM
Methowcats Methowcats is offline
Junior Member
Methowcats is on a distinguished road
Smile Two-Fold Solution to Count Down/Continue Washing Issues.
We had same problem of Bosch dishwasher first starting with 2H, then counting down to 1, then suddenly being at 12, then just washing and washing without draining or ending. We pulled out the board and saw the burned out solder per notes somewhere here, soldered it with rosin core solder, & replaced it in the dw. Ran a cycle, it heated up much hotter than it had been, then it would go thru the cycle, altho it began at 62 instead of 72 for the count down. There was no jumping around with the count down, but it stayed stuck on 1 and still would not turn off. So I did a cycle with the 2 cups of white vinegar in a bowl on the bottom rack twice. (Just to be sure I really got whatever I was cleaning clean.) And it is now working just like new. It is 9 years old, so altho we've never soldered a circuit board before, it was worth the try. I'll add the vinegar trick to my yearly maintenance plan. I have heard of this before for clothes washing machines, especially those that do not have a manual lint collector. Thanks so much to everyone who posted this great information.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher-starts on 2H gets stuck on 1 olijo Dishwasher Repair 5 12-25-2008 11:08 AM
Bosch Dishwasher Dial Stuck JJ2 Dishwasher Repair 0 08-06-2008 08:21 AM
Bosch dishwasher - stuck in rinse cycle bialhome Dishwasher Repair 1 07-15-2008 06:51 PM
Bosch dishwasher stuck on rinse cycle JDDrake Dishwasher Repair 2 04-05-2008 11:10 AM
My Bosch dishwasher is stuck! kevin e Dishwasher Repair 5 04-04-2008 06:09 PM
