Hi I have a Bosch dishwasher with hidden controls. Last week the washer was emmiting a burned smell while running. Then finished up and wold no longer turn on. I removed the access panel on the bottom and noticed the power wire nuts were burnt and fused together.
I stripped the wires all back and re-connected everything. I then plugged the washer back in and the washer does not turn on, Ive dismantled the front and tested the power I have power coming into the machine, to the power switch and back out. I have a feeling it may be the control unit but need clarification.
Any ideas of what else it could be?
